Custom 4.3L forged and sleeved!
Thanks for any info!
-Ghost
If you want a powerful V8 benz a remote mounted turbo would be a much easier route. I've built a rear mount exhaust for a e55 for my mechanic by basically hacking off the rear muffler and attaching a divided T4 flange to the two pipes.
Your m104 is an inline 6 which are known for their structural integrity and great for makinf reliable power even in stock form, good luck with your upgrade!
) And yes open deck. Block 113 I have not heard of any bottom end problems I think the 430 has 4 bolt mains (e55K has 6 bolt mains) I would say all things considered 500 FW HP would be ok for both the engine and trans.What fuel system are you considering?
P.S. in your last post did you mean RWHP (rear wheel HP)?
https://mbworld.org/forums/w211-amg/...55-record.html
FW flywheel HP
RWHP rear wheel
That blower will give your 4.3 about 500 HP at the crank. It's cheaper, easier, and more real than your dreams. Oh, excuse me, maybe you want MORE power than that. OK, chase away, but think TRACTION every once and while, for old time's sake. Get the LSD, get the coilovers, then come back crying for more HP.
I already have a blower, coilovers, with plans of upgrading drive shaft, transmission rear end etc!Thanks for that completely useless bit of knowledge if your going to make rude comments do it on another thread!
Wish I could since he has alot of knowledge about our cars that noone else has. If you are in NOVA we can meet up and discuss different paths and I can tell you what I've learned from my research.
There was a member, Sleestack that tried to do a 6.1L upgrade along with a Kleemann blower. He ended up with upgraded forged internals and the blower.
There are SRT8's running around making 1100whp/wtq with this trans in it
My car really doesn't have much interms of drivetrain and the suspension isn't setup for drag racing (KW v.2's) since I liek to drive it on th estreet and road course too. All I have is the quaife LSD and a modified torque converter. Axles are a weak link for me. I broke 3 already (two weeks back to back!). I sent out an axle to southern hot rod over a month ago but nothing has been made yet. Driveshaftshop told me to send them a sample and they will make me one. But I'm still waiting to hear back from Southern. I think the next weakest link would either be the driveshaft or the gears in the diff
Only time will tell... if I even get back out to the track again.
Do you have any info on this TED Baldwin guy? Im pretty good at finding people.
I too would love to talk with him!
Only time will tell... if I even get back out to the track again.Which makes me think your idea is the best way to go!!
There is a thread about it somewhere. FYI - I am only running ~8PSI, imagine 16PSI, albeit with lower c/r
Is that what you are thinking of doing next??
