Centerlink / Inner Tie Rod / Drag Link....HELP!
. You may want to run a tiny bit of toe, you don't have to run full zero since it does give you a bit more precise handling with a bit of toe. , just have them set toe to stock specs.
You have no idea what you're talking about. When a car is aligned, it's on an alignment rack – and the car is stationary. The alignment specifications take that into consideration, because when the car is moving, the suspension geometry changes. When a car moves in a forward direction, the car's center of gravity moves rearward (weight shift), and the front suspension is unloaded. When the suspension is unloaded, the geometry changes. If the front end of a car had zero camber while stationary, it would have POSITIVE camber while in motion. That's what your alignment recommendation will result in - positive camber while moving forward.
Lots of people purposely run zero camber on the REARS (I am talking about rears, I never said run zero on fronts, please read carefully) for maximum straightline traction. On the front it isn't as significant, usually you run alittle bit more in front than rears. Running Zero on rears is the best way to get maximum traction and the reason CLKs have problems getting power to the ground is they run too much negative camber (especially when dropped).
MarcusF, I'm flattered that you must follow up every single one of my posts via search but don't let it get out of hand, this is the nth thread you done that.
And what’s up with your nonsense about me following you around? LOL I’ve posted over 1100 times. I remember pointing out your insanity twice. You must have me confused with someone.
Zero camber - I’m still laughing. Ever ride a motorcycle? Ever go around a curve with the tires at zero camber?
Is this more accurate for our cars? This data was given to me when I went to have a digital alignment. P.S. Thanks for the DIY complement.
Front
- Front Camber: Min -1 degree 16' | Max -0 degree 36'
- Front Caster: Min 4 degree 23' | Max 5 degree 23'
- Front Toe: Min 1.4mm | Max 3.3mm
Rear
- Rear Camber: Min -1 degree 45' | Max -0 degree 45'
- Rear Toe: Min 2.4mm | Max 3.8mm
Front
I’ve attached a number of photos from an alignment article I wrote several years ago. The first photo shows the pickups on the wheels. Next you can see the camera bolted to the wall. The camera ‘looks’ at the pickups on all four wheels and passes that info in real time to the monitor. The third photo is the monitor, which tells the tech what the total alignment (all four wheels) looks like in real time. The reason all four are important is because changing one corner changes the other three. That third photo is what a 220 S looked like when it came into the shop. It had been aligned three times at another shop and still didn’t ride right. The areas you see in red are why. The last photo is the front end after the alignment. In the upper left of the first green bar, you can see the minimum camber spec. To the right is the maximum. Look carefully at the green bars. You’ll note they’re not flat across the top. Those recesses are the sweet spots. It steps down twice. The tech wants it in the lowest section for all areas, but it’s not possible. Close is as good as it gets. Getting it right for one wheel pulls it out for another – and those are just the front. Adjusting the rear changes the front, and visa versa.
You deserved the DIY complement. It was a four star post and we should be thanking you – you are the man!
i remember reading that some cars were designed to sit higher at the driver's corner to compensate for the driver's weight.
I've never seen a new Mercedes-Benz that sat higher on the driver's side. When changing them, if the spring doesn't seat properly in the pad, the ride height at that corner will be higher. When you pull your pads, you'll notice they are deformed. They do that over time. Rather than trying to fit the new spring in the old deformed pad, some people buy new pads with their new springs.On a W208, caster is indirectly adjustable by using multiple camber bolt kits. This is another good reason for using a shop that has $50K+ in alignment equipment - adjust the camber to change the caster without getting the camber out of spec. Here's a picture of the camber bolt.
Additional photos of the new E-Coupe , which was an add on to another page.
The new AMG SLS Gullwing
That and I'm looking at those Alpine iDA head units.
These are just radios and media managers. They read flash drives, iPhones, and iPods. I'm trying to find out if the flash drive can be replaced with a 500GB USB powered external hard drive. Couple that with the PAC cable so the steering wheel controls still work, and the only other question will be if it will plug into the OE Bose amp, or if new amps, speakers and rewiring is needed. I'm looking at all these projects to take my mind off the fact that you AMG guys are so much faster than us mere mortals.
i cannot understand how shortening or lengthening the lower control arm with camber bolts can change caster.
also, do you know how many degrees 3mm is? i didnt some converting and calculated close to .5 degrees.
Sorry, but I have no idea what 3mm would translate to in degrees.
Seems that Marcus is only providing Constructive Criticism so instead of getting angry debate his argument, prove him wrong, reinforce your argument with factual data or some visuals; otherwise people will lean in his direction which is not good for you because people would question your knowledge about our cars and possibly reconsider buy parts from you.
I am one of them especially seeing that you have not responded to my PM or Emails about my questions to your upcoming V6 W208 Headers
Do you have similar instructions / explanation / diagram for the front?
MarcusForPresident
Sorry to group you in the same post with your Arch Rival
I don't know about president. Those guys never drive cars. Although some have flown fighter jets, which probably make sport bikes seem like driving a minivan . . .
Lastly, someone should start a tech thread on headers/exhaust tech. Tubing diameter, collector angles, negative pulses, it could get interesting. If AMS starts the thread I promise not to post. I don't want to be accused of stalking.
Impressive!! Keep up the good work!
It probably will not cannibalize the CL, since there is the V12TT option in that line.
RIP the CLK!
Part numbers:
2024600505 - Tie rod assembly
1244630432 - Steering damper
Hey sorry to wake up this old post but I need help wth my 98 320clk. I bought it @ 114k lowered on 19's. Still lowered on different 19's @ a little over 170k, thing is still alive n kick pretty damn good for the mileage. For various issues Im encountering like 50-65mph steering shake, steering not feeling right n tight at all, and a random and somewhat dangerous steering stiffing and almost getting stuck at higher speed tight turns (I have to muscle the wheel over and brake to complete the turn till steering engages again, 3/4 turn flop u mentioned?).
So I've been researching all over looking for parts and instruction on what parts I need to revamp this suspension.
Instructions per part I can find, but what parts are good to change, especially @170k, to make the ride and steering brand new?
Here's what I got so far:
Inner and outer tie rods
Wheel bearings
Ball joints
Sway bar bushings
Steering center link
Control arm bushings
Front strut shocks
Anything else you guys can input to make this thing smooth?
Thanks tons
