rear headrests in cabriolet
Old Mar 8, 2009 | 12:58 AM
rolling430's Avatar
03 CLK 430 Convertible "silkie" (sold), 2010 E350 Sport Sedan (graveyard), new wheels coming soon...
does anyone know how to get the back seat headrests to go back down if they are stuck in the upright position. is this associated to the roll bar?
Old Mar 8, 2009 | 01:09 AM
Missinlinc's Avatar
From: GA is home but the Army has me in San Antonio
2000 CLK 320 Drop Top
Try resetting them. Hold the button in the up position for about 8 seconds. If that doesn't work there may be something else wrong. I just recently had to replace the relay switch on mine. Here is the link from when I had to fix mine. https://mbworld.org/forums/clk-class...-problems.html
Old Mar 9, 2009 | 03:29 AM
rolling430's Avatar
thanks!
that did the job.
Old Mar 9, 2009 | 08:31 AM
Missinlinc's Avatar
Glad I could help!
Old Mar 9, 2009 | 08:52 AM
denice25's Avatar
civic
Good job missinlinc...
Old Dec 16, 2021 | 05:04 PM
2dogsrock's Avatar
2000 Mercedes CLK 320 Convertable
I know this is an old thread so I'm hoping for an answer. Missinlinc posted a link to repair the rear headrests that are stuck up on a CLK 320 convertible. I tried to click the link he posted but it did not load anything. If you could repost that link it would be much appreciated!
Old Dec 16, 2021 | 08:47 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Open the following link instead.
https://mbworld.org/forums/clk-class...ering-how.html
Old Sep 7, 2023 | 05:34 AM
dtaBSe's Avatar
2005 CLK320 Convertible
To do it manually there is a small notch on a spring plate that you can depress with a long slender metal rod located about 8" down on the right side of the headrest (when you're in back seat facing the trunk). You''ll feel it because it will give-way about 1/2" like a spring-board lever ... pressing down will cause the headrest will go down. I found it by shining a flashlight down in the space because I had extra room due to the 6 bolts holding the back-rest directly behind the headrests had been removed.
Instructions on You Tube at
