The all elusive "roof antenna rubber boot and gasket" FOUND !!!
Old Apr 16, 2009 | 08:23 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Cool The all elusive "roof antenna rubber boot and gasket" FOUND !!!
www.europartsdirect.com
keyword search antenna...
I know alot of us have been searching and searching so there it is...
Old Apr 17, 2009 | 01:49 AM
unlukky's Avatar
or search part number: MBZ008577
Old Apr 17, 2009 | 01:52 AM
FF_EMT's Avatar
02 CLK430, 86 BMW 325, 66 GTmustang, 97 GTmustang
cool thanks ive been looking for one of these
Old Apr 17, 2009 | 03:10 AM
AMGMB's Avatar
1999 Mercedes Benz CLK430
ohh dam i needed one also! Thanks a lot
Old Apr 17, 2009 | 05:18 PM
vizionclk430's Avatar
2002 clk430
I have the MBZ car cover so I keeped breaking mine ended up getting the one off ebay which is a hard plastic but looks the same but it doesn't bend. I'm speaking of the black part not the whole assembly. I do need a new rubber ring don't know if I want it bad enough to spend $25 for it.
Old Apr 17, 2009 | 10:47 PM
W2O8TC's Avatar
W208
NICE!!!! This isn't for the whole assembly right? Only for the rubber parts? If it is, I wonder how the rubber ( stick thingy ) can be replaced? When I called the dearler, they said the whole assemly comes as one and only the rubber parts can't be replaced since the rubber parts are attatched to the plastic housing as one set. Any ideas???
Old Apr 18, 2009 | 01:46 AM
2002 clk430
The dealer only sells it as one unit but it can be taking apart in the three pieces you see. They don't sell each piece seperate. like I said I just replaced the stem with a hard plastic one because my car cover bends the factory one and breaks it.
Old May 1, 2009 | 07:44 PM
titech05's Avatar
2001 CLK 320
I just purchased the set and all you have to do is stick the rubber tube through the hole of the actual part attached to the roof. Once you get it and see how its structured it will only take 5 minutes to install. Great Cosmetic buy for $25
Old May 10, 2009 | 12:56 AM
Jays_Z's Avatar
Now thats a good find.
Old May 12, 2009 | 01:37 PM
fiddlyd's Avatar
2015 s550 coupe
now where can i get the antenna cover for a cabrio?? the one that goes on the trunk. mine disappered somewhere.
fiddlyD
Old May 12, 2009 | 02:24 PM
M-bENZ's Avatar
Corrolla
is that already painted in silver ? thats what it show in the pic.
Andy
Old May 13, 2009 | 12:28 AM
unlukky's Avatar
Andy
This is just for the rubber boot and gasket. No shell.
"now where can i get the antenna cover for a cabrio?? the one that goes on the trunk. mine disappered somewhere."
That I don't know. Might try and get MBZ part number from dealer, then plug it in to google and see what falls out...
Old May 14, 2009 | 07:11 PM
trinispeed's Avatar
CLK430
That price went up it was 25 before now its 34 dollars.
Old May 16, 2009 | 03:01 PM
unlukky's Avatar
I saw that, just ordered today. Figures . Probably had a little boost in order over the last few weeks and went for it.
Old May 17, 2009 | 04:47 PM
trinispeed's Avatar
CLK430
DIY Gasket maker?
Old May 17, 2009 | 06:13 PM
unlukky's Avatar
DIY Gasket maker?
Would work for the base, but I think would look tacky for the actual top boot.
Old Aug 29, 2013 | 12:10 AM
AndreyK's Avatar
2001 CLK 430
Hi,
I have been to the site but cannot see the part that I am after which is the rubber washer that goes between the body and the aerial to seal it.
I have all the bits, if anyone knows where I can get one and let me know or I could even buy it off you would be great.
