trans problem need help
Old Apr 21, 2009 | 09:08 PM
sick430's Avatar
CLK Cabrio
so after the track last month the trans started acting up, heres whats going on.
1. at low speed very easy crusing the trans will go into over drive
2. at freeway speed or really anywhere over 45 the trans wont go into over drive
3. even when i move the lever over to up shift it still does not go into over drive!
4. there are no codes poping up!!!!
Old Apr 21, 2009 | 09:54 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
Is it possible to reset the ECU like you can in the w203. I tried it once in my '99 w208, but I couldn't really tell. It usually changes the way the car shifts. If you drove your car hard at the track, it may have "confused" the driver adaptive throttle response. You can reset it by:
1) turn the electronics all the way on, but not the engine
2) press the accelerator to the floor and hold
3) after 5 seconds, turn the key off, but DON'T remove the key THEN take your foot off the pedal
4) wait a couple (two) minutes and it should reset
I hope this helps you.
Old Apr 22, 2009 | 01:00 PM
sick430's Avatar
CLK Cabrio
thanks bro totally forgot about that!
I'll try it as soon as i get home and will post if it helps!
thanks again
Old Apr 22, 2009 | 01:24 PM
Chappy's Avatar
AMG
Have you ever had the transmission fluid changed?
Old Apr 22, 2009 | 05:06 PM
bdgdl08's Avatar
I would be careful about changing the fluid, the transmissions were designed to be a sealed system. I had mine for 232,000+ miles without a fluid change.
Old Apr 23, 2009 | 01:11 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Cool
No offense, please...
But don't do this. Fluid is fluid and it WILL break down. 30k intervals = change it.
Old Apr 23, 2009 | 07:42 AM
Chappy's Avatar
AMG
Yep, and the diff fluid too. Tracking a car puts lots of added stress on components....keep everything as fresh as you can (brake fluid/tranny/diff/oil).
To the OP:
Have you spilled any liquids down the shift gate?
How many miles are on the car?
Has the transmission ever been serviced?
Exactly how hard do you drive the car? Any burnouts?
Old Apr 23, 2009 | 08:40 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
i change transmission oil every 3 months, i drive the car hard every day... from dragging, to burnouts, to power sliding ... u name it i do it
but all in closed environments (unused roads, empty parkings, etc...)
Old Apr 23, 2009 | 03:02 PM
sick430's Avatar
CLK Cabrio
To the OP:
Hey Chappy,
no spills, my car has 71K on it and i have had it since it had 25K.
i have had the trans serviced every 30K miles!
i drive it hard but am normally easy off the line and don't do burn outs really maybe once in a blue moon, waste of tires and 275 are $$$$!
hopes this gives some insight!
sick430's Avatar
CLK Cabrio
thanks for all the input guys!
Old Apr 23, 2009 | 03:03 PM
sick430's Avatar
CLK Cabrio
thats the way it should be driven!!!
but i cant get any more tickets there killing me!
Old Apr 29, 2009 | 04:46 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
MarcusF posted the following in his thread "my 722.6 mega-dollar transmission":
Regarding the car, the plate is busted, so they're replacing that. While they're at it, they'll do the infamous "transmission wiring harness o-ring job". Mine wasn’t leaking, but it’s a two dollar o-ring, so while they’re there, it only makes sense to change it. It's my understanding that when the o-ring leaks, ATF commonly finds it's way to the transmission control unit, and the metallic bits in the ATF fries the TCU. Naturally it's getting a fluid/filter change.
I know you said you were getting the trans serviced every 30k (?) miles but are they changing the transmission wiring harness/connector and O-rings? I found out these are supposed to be changed during every transmission service. A leaking one (no fluid on the floor. the fluid seeps up into the TCU, transmission control unit) will lead to weird transmission problems. My indy said if the connector/harness didn't fix the issue, he wanted to change my shifter (NOT!). Trans is fine after the connector/harness swap.
Old Apr 29, 2009 | 07:51 PM
sick430's Avatar
CLK Cabrio
thanks, i will be going to my indy shop very soon! he is the best so he is back up a little!
Thanks everyone!!!
Liran
Old May 8, 2009 | 10:03 AM
Chappy's Avatar
AMG
Thanks everyone!!!
Liran
Any news? How is the transmission working?
Old May 10, 2009 | 04:12 AM
sick430's Avatar
CLK Cabrio
Hey Chappy,
My mechanic sent me to his transmission person as he is not too familiar with our transmissions and as I have no codes popping up, he felt his friend would be better! He wasn’t, his idea was to have me through money at the trans until he got it right. I wasnt having it so I left!
As it stands, I haven’t been driving the car to often as I have a second car! Nevertheless, I need so expert advice from you guys and girls.
Here are the full symptoms’:
Even if I am driving downhill, if I am over 40 MPH, the overdrive does not engage even if I move the lever to the right.
Car will shift into over drive if I am under 40 MPH, however, it will not engage overdrive if I do not move the lever over to the right while driving under 40.
There are no other shifting issues! All other gears work fine!
I believe it to be the speed sensor.
Any suggestions to what it maybe is appreciated!‼
Old May 11, 2009 | 08:17 PM
sick430's Avatar
CLK Cabrio
anything??
Old May 11, 2009 | 10:00 PM
gregory13lil's Avatar
2000 CLK430
Just do what I do sometimes....Take it to the dealer for a diagnosis (free or at most 1 hour labor) and then find out what the REAL problem is and see if it is something that you can repair or at least have your Indy repair themselves. You are not locked into having it repaired by the dealer until you give them the go ahead so use them for the experience and get the right diagnosis.
Greg
Old May 12, 2009 | 06:50 AM
Chappy's Avatar
AMG
If it were me, the next step is to a pro for a full diagnosis.
Old May 12, 2009 | 02:31 PM
sick430's Avatar
CLK Cabrio
yeah i was planning on taking it in this week after finals!
any good dealers around LA? willing to drive for a good one!
Old May 12, 2009 | 03:47 PM
MarcusF's Avatar
2002 CLK430
The best SoCal indy I know of is Mr MB Motors,5557 Reseda Blvd, Tarzana, CA 91356. Phone: (818) 708-8086
Other than him, I use Mercedes-Benz of Valencia. The service advisor you want is Mr Castro. Tell him Marcus Fitzhugh sent you. No rapage, C300 loaner, clean car when you pick it up, and it's fixed right the first time.
Old May 12, 2009 | 04:43 PM
moondust's Avatar
2004 CLK 240
Reading up on this, it seems that the shifting points are determined in the ETC module (N15/3) based on various inputs. Also involved are the kick-down switch (S16/6) and the Electric valve control unit (Y3/6). An ETC diagnostic test will indicate the current shift points.
Attached Thumbnails trans problem need help-2.jpg   trans problem need help-1.jpg
Old May 12, 2009 | 05:11 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Do pedal ECU reset to reset adaption parameters for the transmission, as well as, a transmission fluid flush @ the dealership.
If that does not fix the problem your K3 clutch pack may be going out, but typically you would feel slight slippage when going into 4th gear. However in your case it starts to sound more like an electronic issue vs. a mechanical one. However, the 208 CLKs had weaker tranny internals than the later ones and the K3 clutch pack is almost always the first to give b/c it is used for 4th & 5th gear, reverse1, downshift into 4th, and downshift on decel into 2nd & 1st so its used all the time and its a much smaller diameter than the main clutch packs in 1, 2 & 3 (which are significantly stronger).
Pray its not the clutch packs... if it is.. $2500 min to rebuilt.
Hope that helps
Old Jul 21, 2009 | 02:12 AM
unlukky's Avatar
Cool
I understand this 'wicking' that occurs when the fluid seeps upward thru the TCU harness and suspect that my O-ring is going bad. I just had the car serviced. My indy mentioned to not only change the O-ring, but to change the harness adapter. He says that there is an updated version running around. Do any of you fellas got that part number. He said he would do it for 1/2 hour labor, but wants me to get the part.
Thanks, John
Old Jul 21, 2009 | 04:26 AM
unlukky's Avatar
Initial search = no good.
further diligence = success.
http://www.autohausaz.com/search/pro...0540%2002%2053
Thanks anyway.
FWIW. Everyone should think of updating this plug at your next Trans service.
Old Jul 21, 2009 | 08:46 AM
2000 CLK430
Thanks anyway.
My tranny has no shifting issues but I have heard about this o-ring job before. WHY exactly does a new one need to be replaced for the old one. Is it due to bad design causing a leak, or is it just fair wear and tear? Also, where exactly is this plug located?
Greg
