Do C32 brake kits fit W208s?
Old Feb 16, 2003 | 04:58 PM
ViKTORiOUS's Avatar
W209 - W163
On the website for Autowerksexpress.com, they are selling big brake kits from C32 AMG's and they say it can fit other Mercedes Benz models. The price is good, im mainly going for the look. Do the E55 AMG's have kits like this that i can buy online? Thanks!
http://reswest.com/
its on the home page, you should see a pic of a C32 wheel.
-Vik
Old Feb 16, 2003 | 06:07 PM
Mach430's Avatar
The C32 are not made for the CLK.
Old Feb 16, 2003 | 06:10 PM
ViKTORiOUS's Avatar
W209 - W163
is there an AMG W208 brake kit?
Old Feb 16, 2003 | 06:14 PM
Mach430's Avatar
The CLK55 has bigger brakes, but they are not Brembo calipers. I may have a customer with a used set soon. If you're interested, I can send him your contact info.
Old Feb 16, 2003 | 07:25 PM
ViKTORiOUS's Avatar
W209 - W163
i want something that will make my brake looks nice but i have the money to spend 3k on brakes. i was hoping i could get something for like 600-700. Where can i get brembo calipers to match the CL55 brakes?
Old Feb 17, 2003 | 12:38 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Ben, Do you know if the W209 brakes & calipers will fit our W208? The W209 calipers look a lot better (at least the CLK500)
I heard they increased the size of the rotors for the W209, would that effect the contact patch?
Old Feb 17, 2003 | 01:35 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
W209 calipers are leading. W208 calipers are trailing. Would require quite a bit of fabrication to make it work, including machining off the caliper bracket from the new caliper. Same goes for W203 (since the W209 is based on the W203).
-s-
Old Feb 17, 2003 | 03:29 AM
Mach430's Avatar
Unfortunately, the 2 easiest ways to upgrade your brakes are going to be either the CLK55 brakes, or a big brake kit (which will outperform the C32 brakes anyways).
Old Feb 17, 2003 | 11:10 AM
ViKTORiOUS's Avatar
W209 - W163
So i cant buy calipars alone? I was thinking getting Brembo or Zimmerman Rotars and buying calipars from mercedes. But i guess that cant work, i just like how they look and say AMG or Mercedes-Benz
