undervoltage light and battery/alternator light
First the undervoltage light came on and then the battery/alternator light came on. Before I could take it in, it died and the battery wouldn't charge. I'm thinking it is either the voltage regulator or the alternator. Has anyone had this problem? Weird thing is, all this happened after I plugged my new ipod touch in my car.
I really hope it is the voltage regulator...a lot cheaper!!! All I know is everyone says not to go to the dealership as they cost way more! I love my benz but it seems that lots of people with the c class has had this same problem.
Thanks for the reply back!!
My sunroof wont open, driver window doesn't work right and this srs light came on and said to visit workshop.
The place that worked on it told me "they didn't touch anything else." I have no clue what's going on and will take it some where else.
Do a search on this forum for the reset, there is nothing wrong with the car. It is a normal procedure that must be done when the car loses power.
Greg
That makes sense. I am a girl and know nothing about cars!! Still confused why the srs light would come on telling me to visit workshop. I really don't want to spend way more money by going to the dealer but thinking maybe I should? Otherwise, a friend referred me to a mechanic that works on foreign cars. I love my benz and I know its a great car, but it frustrates me dealing with all the mechanical stuff!!
If you have one-touch windows, push the right window switch all the way down and hold it until the right window is all the way down. Then push the switch, hold it, and raise the window all the way up. Do the same thing for the left window. Now your windows are set.
If you have a one touch sunroof, press the button to open, and hold it until the roof is fully open. Now close it. The roof is set.
Without sitting in it, move the driver’s seat all the way forward. Now move it all the way back. Do the same for the passenger seat. The seats are set.
Turn on your stereo and enter your radio code. If you don’t have the code, you can forget about listening to the radio until you get it. The dealer can give you the code for free.
To turn the srs light off by turning the steering wheel...does the car need to be on? My seats are okay 'cause they are not electric. My radio is working fine so don't think that needs reset...unless that has something to do with the other problems?
My passenger side window is working fine. The only problem besides the srs light- driver side window rolls down fine but does not roll up automatically when pressing up button once...and so I have to hold the button up to roll up...shade for the sunroof is also supposed to open automatically but I have to hold the button to get it open..and then when the shade is open, the sunroof window will not open at all.
I just think it is weird that only driver side and sunroof are affected.
Thanks for your help!!!
I got a custom 200 amp alternator built for my stereo and neon lights. Is the voltage regulator internal or external and do i need to make some modifications to the regulator to actually benefit from the added amps?
Benz-C230: yes, the engine should be running.
Nasty: I PM'd you.
All I needed was a new voltage regulator which was good 'cause it could have been the alternator and that would have sucked!!
