SO3 Tires Sizes
Old Feb 24, 2003 | 10:58 AM
SilverBullet's Avatar
2001 CLK 430
SO3 Tires Sizes
What is the maximun size Bridsgestone SO3 that I can use on AMG Monoblock II 19x8.5 and 19x9.5. Im planning to roll the fenders and lower with H&R springs. If I can't use SO3, which other brand of tires would you recommend?
Old Feb 24, 2003 | 01:42 PM
Mach430's Avatar
235/35/19 265/30/19
Bridgestone doesn't make the S03 in a 235/35/19. I would suggest going with a Toyo T1s.
Old Feb 24, 2003 | 01:54 PM
2001 CLK 430
Originally posted by Mach430
235/35/19 265/30/19
Ater Toyo T1s, how would you rate the other tires. Especially, P7 and Dunlops?
Old Feb 24, 2003 | 02:07 PM
2001 CLK 430
Or would you go with 18x8.5 and 18x9.5 with the SO3s
Old Feb 24, 2003 | 04:01 PM
Mach430's Avatar
The Toyo's are just as good as the SO3's. I would much rather substitute the S03's for another tire, than choose a smaller wheel size just to be able to use S03's.
Old Feb 24, 2003 | 05:09 PM
J Lucas's Avatar
Don't the toyo's blow out on potholes very easy? More so than the MPS A/S or the s03's?
Old Feb 24, 2003 | 08:15 PM
Mach430's Avatar
I've never heard of it happening. If you hit a pothole hard enough to blow a tire, my guess is that it doesn't matter what tire you have...
Old Feb 24, 2003 | 09:25 PM
J Lucas's Avatar
You obviously havent been to NY recently, it doesnt matter what speed you are going for a pothole to bite u in yur ***. But i used to have toyo's on my clk and had 7 flats(blow outs) within like 6 months.
Old Feb 24, 2003 | 09:37 PM
Mach430's Avatar
I go around them
Old Feb 24, 2003 | 09:54 PM
tery's Avatar
CLK320
anyone here use the polit sport cup ? what you guys think of this ? good or bad ?
Old Feb 24, 2003 | 11:35 PM
Dave OH's Avatar
R170
Isn't the Pilot Sport Cup an R-compound tire? I wouldn't recommend using r-compound tires for everyday street use.... however, for track use I have heard good things
Old Feb 25, 2003 | 01:38 AM
hinhin7's Avatar
MB
Where can you get R-compund tires? How much are they?
Old Feb 25, 2003 | 01:53 PM
Mach430's Avatar
Yes, the Pilot Sport Cup tire is a R compound tire. You should be able to get this from Tirerack.
