Rubbing issues with new wheels
Old Jan 25, 2010 | 11:12 PM
trinispeed's Avatar
CLK430
So I got new Euro63RS on my car(8.5 in front and 9.5 in rear). And on my front when im in reverse and turn my steering wheel left my front right tire rubs on something. It is not the wheel well or fenders. What else could it be?
Old Jan 25, 2010 | 11:40 PM
Jays_Z's Avatar
I"m having the same issue with mines
Old Jan 26, 2010 | 09:40 PM
trinispeed's Avatar
CLK430
Yeah, I think multiple people around here would. Im just waiting to find out what it is.
Old Jan 28, 2010 | 09:51 PM
trinispeed's Avatar
CLK430
Anyone?
Old Jan 28, 2010 | 10:09 PM
dlbehrns's Avatar
99CLK320,
put it on a hoist that lifts the car by the tires so there is a load on the suspension, turn the wheel all the way to the left, raise it up and look under the right wheel. that has to be something that is close to rubbing something. does it rub on the rubber tire or the metal rim? take the wheel off the car and look for ware marks on the tire and the rim. does the left wheel rub when you back up with the wheel turned to the right? does it rub going forward in either directions? process of elimination should give you an answer.
Old Jan 28, 2010 | 10:59 PM
Ghostrider's Avatar
01 CLK 430
What size tires are you running?
Old Jan 29, 2010 | 12:41 PM
trinispeed's Avatar
CLK430
245/35/19. Not stretched or anything. On a 8.5 inch rim.
Old Jan 29, 2010 | 04:46 PM
Ghostrider's Avatar
01 CLK 430
You should be running 235/35/19
Old Jan 29, 2010 | 10:07 PM
vizionclk430's Avatar
2002 clk430
Yeah I run a 235/35/19. that may be your problem
Old Jan 31, 2010 | 10:24 AM
Jays_Z's Avatar
I put the stock wheels on and still have the same problem.
Old Jan 31, 2010 | 03:50 PM
2002 clk430
^^^^^^^^^^ what are you lowered on and what pads?^^^^^^^^^^^^
Old Jan 31, 2010 | 10:40 PM
trinispeed's Avatar
CLK430
Had it on a lift in the air. Took a look at it and had the mechanic look at it real quick. Could really find anything. The rim is fine. I think its probably the tire rubbing somewhere on the plastic.
