What's best for lowering a '00 CLK430?
Old Mar 20, 2003 | 08:46 PM
cl_kruisin's Avatar
2000 CLK430 & 2000 Expedition on 22's
Question What's best for lowering a '00 CLK430?
What do you guys recommend for lowering a CLK 430? Just lowering spings? Or.....? I haven't decided on either 18" or 19" wheels, does anyone know how many inches you can lower it on either 19's or 18's? I am hoping to lower it as much as possible on either wheel size.
Also, just curious, what do you guys run, suspension wise on your CLks?
Thanks Again...
Old Mar 21, 2003 | 04:55 AM
davidhung78's Avatar
2003 E55
Almost everyone will tell you to use H&R springs....listen to them. I went with Eibachs because I wanted a more conservative ride, but I was NOT a happy camper. H&R's will drop a lil more and have a stiffer ride but it is worth it. Eibach's supposedly drops 1.2"front and rear, but I have 18"brabus and I still have atleast a two finger gap on front. H&Rs supposedly 1.4front and 1.3rear.
Old Mar 22, 2003 | 05:42 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
For the best value on your money, get the H&R Cup kit, which comes which shocks & springs.
Old Mar 22, 2003 | 06:02 AM
xyzpl's Avatar
S60R, ML320, W211/E350
I agree with theine, get the cup kit, you won't de disapointed!!
Old Mar 22, 2003 | 12:48 PM
hinhin7's Avatar
MB
With the cup kit, do you have to get the alignment kit, coz on the H&R website, it says that the cup kit will cause some negative cambers.
Anybody familiar with the Bilstein suspension system. I remember they have pss and pss9. are they the same as coil over?
Old Mar 22, 2003 | 01:50 PM
theine's Avatar
Nothing wrong with a little negative camber, which you also get with H&R springs alone. The car looks nicer and handles better.
Old Mar 23, 2003 | 04:18 PM
hinhin7's Avatar
MB
If I use coil over or anything that is height adjustable, when I change the height, do I have to do the alignment again?
Old Mar 24, 2003 | 08:31 AM
theine's Avatar
If you noticed that the car is pulling to one side, any way it is a good idea to align it everytime you work on the suspension.
