CLK 50 K ;)
Old Mar 31, 2010 | 04:05 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
CLK 50 K ;)
Greetings,
Teaser pics of what i have been up to the couple of months
BIG special thanks for my friend Ali Saklaoui (Autodynamics Garage ~ Beirut Lebanon) for making all this happen.
Newly Added to the car :
# w211 E 55 Kompressor Superchargercomplete Take Off
# w203 C 32 Heat Exchanger with OEM Water Pump
# w220 S 55 Transmission (non Kompressor)
# w211 E 55 Kompressor Spark Wires (~8.5mm)
Car still retains MAF and ALL w208 ME2.8 Electronics, Custom Tuned By Jerry Thornton.
Still need alot of fine tuning waiting for parts to arrive
Attached Thumbnails CLK 50 K ;)-img00083-20100330-1719.jpg   CLK 50 K ;)-img00084-20100330-1720.jpg
Old Mar 31, 2010 | 08:29 AM
rrich49132's Avatar
2005 c55
Very sweet!!
Must have been lots of $$$ to do all this?
Old Mar 31, 2010 | 12:07 PM
ahmed18881's Avatar
Originally Posted by rrich49132
Very sweet!!
thanx
sure it does, the parts add up quickly, but it well worth it, will post a video as soon as i get it perfectly tuned.
Old Mar 31, 2010 | 12:17 PM
BLKCLK550's Avatar
09 CLK550
MOZA FAKA!!!
Old Mar 31, 2010 | 05:24 PM
Ghostrider's Avatar
01 CLK 430
Originally Posted by BLKCLK550
MOZA FAKA!!!
I like that, 50K....
Old Mar 31, 2010 | 05:31 PM
ahmed18881's Avatar
MOZA FAKA!!!
lol i hope u mean it in a good way hehehe
Old Mar 31, 2010 | 05:32 PM
ahmed18881's Avatar
thanx
Old Mar 31, 2010 | 05:46 PM
malahhaor's Avatar
06 Carrera4
so you took a 500 engine and slapped an E55 kompressor on it?
Which ECU tid you use? your original, the one came with the 500 engine or one from E55?
Old Mar 31, 2010 | 08:41 PM
BLKCLK550's Avatar
09 CLK550
Obviously in a jealous way!
Old Apr 1, 2010 | 05:58 AM
ahmed18881's Avatar
the car came with originally as a 2001 clk430, swapped the engine for a 500 from a w220 (changed the oil sump and oil pan to sit in the clk bay), then slapped on the e55k supercharger, needed bigger injectors and a custom tune to do that. The car now is a complete "*******"
w220 S500 engine, w220 S55 NA transmission, w211 E55K supercharger, w210 E320 3.07 differential, w208 CLK 430 ECU, "AMG" TCU i have speed shift .
now looking for big brakes, Methe system, oil catch can, and maybe a bigger crank pulley (168 mm "old renntech one") ...
Old Apr 1, 2010 | 06:00 AM
ahmed18881's Avatar
as they say don't hate the player hate the game loooooooooooooool
Old Apr 1, 2010 | 07:29 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Wow! What a project! You practically have every performance mod I've been wanting to get. Have you gotten that beast on the dyno or on the 1/4 mile track?
Old Apr 1, 2010 | 08:15 AM
ahmed18881's Avatar
still have a problem in fueling at high RPMs, but i tried a ghetto 1/4 mile run (we don't have drag strips nor do we have a "functional" dyno in Lebanon ) it does 112 mph, this is with a cylinder misfire, and very very bad traction ... so based on a formula on http://www.aspracing.com/index-5.html, which i put my cars weight then trap speed it gave me HP, then put the HP and Weight in the formula below it gives me an estimated time ...
values i plugged the first formula are
3461 lbs, and 112 mph gives me 379 rwhp
then plugged these in 2nd formula below
12.17 secs
yesterday i tried to pull next to a friend that has a M5 V10 (507hp) from a rolling start of 20 mph on the first gear he pulled a car length due to very bad traction then i caught him on second gear my car's nose on his front doors, 3rd gear stayed the same, until my car misfired and we stopped. my car is running in a very safe setup, ignition retarded very much from original (~14 degrees) and with low octane fuel in DAS software too and AFR is between 10~11.5, when i finish from the fueling issues & an aggressive tune we are expecting much much better results
Old Apr 1, 2010 | 11:55 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
What are you using to do the tune? Is it a piggy back or are you flashing the stock ECU?
Old Apr 1, 2010 | 12:49 PM
deyainrdy4ds's Avatar
w208
woww thru the e55 blower on the 500 motor?? sickkkk work!
Old Apr 2, 2010 | 05:52 PM
ahmed18881's Avatar
i am re flashing the stock 430 ECU, to accomdate for the 55k injectors, retard timing, remove load limit, change MAF readings for the increased air... all done by Jerry Thornton he does magic with his files...
yup yup, how is your turbo install going? very very nice work you have done too
Old Apr 2, 2010 | 07:01 PM
nastyclk's Avatar
Supercharged CLK430 street/show car
5.5L
Just curious why you didnt just slam a 5.5L in there? Still a sweet swap!
Is Jerry a tuner or just good with mercedes? Me and another member are trying to figure out tuning options we can do ourselves and cant find the software that can read our ECU's and make changes to them. I would love to talk to him or maybe you can put a bug in his ear for us? We would greatly appreciate it!
Old Apr 3, 2010 | 01:02 AM
buffyclk500's Avatar
clk500
Nice set up
Old Apr 3, 2010 | 08:40 PM
ahmed18881's Avatar
PM Sent
Old Apr 3, 2010 | 08:45 PM
ahmed18881's Avatar
Originally Posted by buffyclk500
Nice set up
Old Apr 11, 2010 | 11:15 PM
blackbenzz's Avatar
haters crazy
Cool, hope you get the tuning sorted out!
Couple questions. How is the Bosch 044 fuel pump working out for you? Did you switch all your pulleys to a 8 rib setup?
Old Apr 13, 2010 | 05:52 AM
ahmed18881's Avatar
heyyy
the man with the fastest street legal CLK!!! how u doing???
well the bosch 044 pump was quite an easy install, but u need the right fittings and u need to fabricate a clamp instead of the small one already there, i also had to raise the pressure to 5bar (using 1:1 fuel pressure regulator) to make the e55k injectors happy, the most annoying thing is the sound, and i have a feeling that when it whines too loud its heating the gas which is a performance draw back. there are people who covered it with a layer of rubber and no longer have an issue with the sound, but i don't think this will help regarding heating.
as for the 8 ribbed setup, as u probably know the e55k has 2 belts, u will need to buy all the pulleys of the e55k including one small bracket for one of the pulleys didn't find it in the us got it from a dealer in germany. i have the part number if u like. Also u need a tensioner and a new water pump, in my case i also needed the thermostat with housing too. but i suspect this will work right in your kleemann setup, did u look under the hood of the C32/slk32 crossfire srt6? they should be identical to the m113 engine but with 8 rib instead of 6 rib?? just food for thought...
i will really be glad if u can ask the guys how built up your transmission if they can sell me a kit? and i install it locally here? i already swapped out the soliniods to the blue tops one, shifting is firm, but i feel its slower
u know ur car inspired me the most that a clk can be fast!
Old Apr 13, 2010 | 09:25 AM
blackbenzz's Avatar
haters crazy
Lol thanks I'm good.
Thanks for tall the detailed info
The people that built my trans are called Southern Hot Rod. I was dealing with Eddie there. I don't know if they can send out parts because I asked them the same thing years ago but maybe they have changed. Wouldnt hurt to give them a call and see what they can do for you. The prices have come down too
Thanks for the compliment. Your car must be fast now!
Old May 4, 2010 | 12:32 PM
Ghostrider's Avatar
01 CLK 430
Can I get some info on your tuning setup??? Please...
Old May 4, 2010 | 01:34 PM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Wow im so jelous of this set up, looks like you have it under control though...
