Electric radiator fans not spinning
Here's a link to my website where I have a pictorial "how to".
Best of luck.
http://www.panchogun.com/FVWebPhotos...bin-Filter.jpg
Meanwhile keeping your heat on MAX HOT will help you get the engine temp down.
You can also try the diag https://mbworld.org/forums/clk-class...-features.html
Sensor 20 should show a high value when the fans are supposed to kick on meaning that the regulator should be getting power if you want to test for voltage at the connector.
My ECU programming was still STUCK as "transport mode" and tuning was set at 89 RON and both fans were DISABLED in the programing.
My independent Tech was able to reprogram the ECU and re-activated the fans, and reset my car to 91 craptane, as 93RON is not available in California....
I was able to see this work done LIVE in his shop.... I have experience with the BMW carsoft and played with the GT1.
i had earlier the same issue for my CLK230 1998
the cooling fans located front of the radiator were not working .suddenly stopped also it affected the compressor as not engaging also. i have tried many things . after searching here in MB world, i found some helpful ideas that helped me to tell the tech about the problem and i had solved the problem by only 35 USD . and by W40 oil .
cant imagine that as we found the Data Cable going to Sensor no 5 located under the front fog light left side . loose connection and one cable full of corrosion , just cleaned ,and no more issue ..
working normal . AC is normal and cool . and compressor is engaging
hope this will help in future and not to let ppl fooled in case of maintenance charges .
here is the sensor
your reply to the subject seems to be the best and cheapest
.I have the same problem in my car but I don't know if these wires are easy to be seen and replaced?! or I have to remove the front bumper to to that!
thnax
Best of luck.
https://web.archive.org/web/20111018...bin-Filter.jpg
