RPM or Trans prob or what ???
Vehicle seems to be stalling. At first I thought it might be a shifting prob, but sometimes it seems that it's the engine that fails to rev up. When I try to accelerate, if I give it a good dose of pedal, the engine doesn't want to rev, and then it seems at though the trans either shifts when it shouldn't, or fails to shift when it should. I can get to speed, 80 MPH+, but I have to do so with a slow steady pedal pressure.
AM guessing MAF (orig.), or fuel filter (orig.), or fuel pump (orig.), or plugs (replaced 35K ago), but really don't have a clue.
Any help determining the issue would be greatly appreciated.
Here is how you confirm if it is the MAF. First locate the MAF sensor, there is one plug to the sensor. Disconnect this plug and cable tie it to the side so it doesn't get caught in the fan/belt when you drive it.
Take the car for a quick test spin, if its running better then its a safe bet that its your MAF.
are we talking about the same sensor here ?
The MAF is about 4 feet from any belt,
at the rear of the intake manifolds,
at the firewall.
What sensor are you describing near the belts ?
Thanks.
1. Poured a bottle of STP octane improver into tank. Had been burning 89 octane instead of 91. Result: Helped a small bit with acceleration. Hesitation, bad lag, erratic shifting, etc. still there.
2. Unplugged MAF sensor. Did this while engine was running--engine died; at restart had CEL. Drove to work that way, and vehicle died at red light, but started up again. After parking at office garage, I connected the plug to the MAF. Result: Engine ran worse with the MAF unplugged--same bad symptoms as before, plus it died twice. With MAP plugged in again, CEL went away, but same hesitation, bad lag, erratic shifting, etc. still there.
3. Reset ECU. Result: Best improvement, but problem, though reduced a bit is still there, hesitation, bad lag, erratic shifting, etc.
I can't tell whether the lag produces the erratic shifting, or whether it's the other way around, the erratic shifting produces the lag.
I will connect it to my multiplexer this week end and look for codes and post a follow up, but instrument panel indicates no codes when I scroll through.
Question: Vehicle has the original fuel pump and filter.
1. What is the service life of the filter ?
2. How test the pump?
Thanks.
also get some 93 octane in that tank and a bottle of chevron techron, and a new fuel filter. i doubt the pump went bad
Another question: What is the service life of the fuel filter ? Mine is the original year 2000 filter @ 103,000 miles.
I'll try to get to this over the weekend, but have promised a friend I would bead blast a couple of Model T carbs for him to rebuild. Imagine that, 100 year old carbs. There's service life for you.
yeah it shoul work, just let the gas leak out(dont ignite it) and go over everything. first do a visual inspection, then try that. and clean the maf the way i described. im not too sure what the life of the fuel filter is but 100000 miles seems more than enough to make you change it anyway even if nothings wrong with it. its only a $30 part and takes literally 20min. to do, easy. let me know what happens.
http://www.panchogun.com/FVWebPhotos...-MAF-5x100.jpg
I'd like to know what you figure out with this!!!
