Brakes? Indicators for wear?
Old Apr 4, 2003 | 07:02 PM
nickv's Avatar
Used to be a CLK430
Hey fellas,
Do our brakes have 'sensors' or 'indicators' that tell when they need to be replaced.
I have a sqeak from around 20 - 0 when applying the brakes in a normal fashion, but it's not there under light or heavy braking...confused.
BTW, it's coming from the front...
Any ideas?
TIA
Old Apr 4, 2003 | 07:56 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
i believe the clk suppose to have wear indicators that show up on the dash cluster display... i'm not sure about MY98-99 clks though.
Old Apr 4, 2003 | 08:29 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: Brakes? Indicators for wear?
Originally posted by nickv
Hey fellas,
Any ideas?
TIA
Your pads have wear sensors built into them, but you'll only get a display if the friction material wears down to the sensor. The problem you are having is that the backing plate of the brake pad is rubbing on the caliper due to lack of anti-squeak grease. The pads have to be removed to put more grease on, and if you go that far, it makes sense to just put a brand new set of pads on anyways while you have the wheels off.
Old Apr 5, 2003 | 01:07 PM
nickv's Avatar
Used to be a CLK430
Thanks guys!!
Now if I want to do this myself, is it possible?? Also, I was looking online for parts for the front brakes, looks like I will need:
Pads
Sensors
Anti-sqeak grease
Is this right?
But what brand to buy??
Pagid
PBR
ATE (Teves)
Textar
Thanks!
Old Apr 5, 2003 | 01:19 PM
E55AMG99's Avatar
1951 Caterpiller D6
Re: Re: Brakes? Indicators for wear?
Without turning the rotors? This will only invite more sqeeks and other problems. Always have your rotors tuned when replacing brake pads. If you have more than 50% of the pad remaining, it probably does not make $ sense to replace them and turn the rotors. Besides, you can only turn them a few times before you must replace them which will drive your costs even high.
Old Apr 5, 2003 | 01:38 PM
mbtech208's Avatar
Re: Re: Re: Brakes? Indicators for wear?
Mercedes-Benz does not recommend turning brake rotors. We don't have a brake lathe at the dealer for this reason.
Old Apr 5, 2003 | 01:43 PM
E55AMG99's Avatar
1951 Caterpiller D6
Really? I stand corrected but don't try to replace the pads on an American car without turning the rotors! I've never kept a Mercedes long enough to have the brakes replaced
Thanks for the info.
Old Apr 5, 2003 | 03:03 PM
nickv's Avatar
Used to be a CLK430
How long should pads last under slightly harder-than-normal driving conditions?
Are the fronts and rears different?
