Who all here...
Old Jun 25, 2010 | 05:50 PM
Ghostrider's Avatar
01 CLK 430
Who all here...
Are running springs with no spring pads, whether it be front or rear:
How does it ride?
Are there any funny sounds? You know, like metal grinding or clunking.
I'm just looking for pros & cons of doing this.
Old Jun 25, 2010 | 06:35 PM
dlbehrns's Avatar
99CLK320,
how low can you go? I haven't heard/read any complaints wrt no pads but logic would seem to say that there would/should be more road vibration translating into the cabin and or some metal on metal noises of some kind, no? MB made those pads for a reason, no?
Old Jun 25, 2010 | 06:47 PM
Ghostrider's Avatar
01 CLK 430
One would think, but you never know why they do things sometimes!! I could always make up some thinner peices for the front.
Old Jun 25, 2010 | 09:35 PM
vizionclk430's Avatar
2002 clk430
I know big_mike1979 and clk fan are don't know about issues with them though
Old Jun 25, 2010 | 09:54 PM
Williams707's Avatar
2000 CLK 320
Others have shaved the pad down until it meets the top of the spring. This would be the same difference as having no pads for those that worry about spring play.
Old Jun 25, 2010 | 10:59 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
i got no pads at all Ghost...
When it gets so cold where im and if snow and salt got into it, it will squeek lil bit, ( i grease it up and gone).
When im rolling on the road is like i have pads, i dont feel anything.
when i go over speed bump, once in a while it make the clunk noise since spring move lil from top(no pad), other than that, im happy young buck and no complaints at all.
Old Jun 25, 2010 | 11:10 PM
2000 CLK 320
Exactly, so you can solve this issue by taking a spring pad and shaving off the top/ cutting the pad down until it meets the top of the spring..
Back at ya Brofrom last time.
Since I can't beat you in the gym I'll beat you here
Old Jun 25, 2010 | 11:16 PM
i thought about doing this but with the time, it will break/get chewed since rubber gets sooo thin, so might as well, go with no pads
and if pads are not even , once side will look lower and other higher
Old Jun 25, 2010 | 11:22 PM
2000 CLK 320
Well stop comparing your Left Peck with your Right, get out of the mirrorStep Away from the Mirror!!!!
Old Jun 25, 2010 | 11:39 PM
2000 CLK 320
Link to this discussion of cutting the spring pads with pictures.
http://www.benzworld.org/forums/w208...ml#post2847339
http://www.benzworld.org/forums/2847339-post1.html
Old Jun 26, 2010 | 12:06 AM
i remember reading that thread *****.....
but it seems he has like pad #3 or 4 and it was tooo thick.
again if its not even, it wont be level..
if u can get em to be level , why not...
Old Jun 26, 2010 | 12:15 AM
Ghostrider's Avatar
01 CLK 430
Thanks for the thread!! I tried that once but couldn't get the cut straight. I was thinking of getting some scrape rubber to fit up in there.
Old Jun 26, 2010 | 08:19 PM
One more thing i forgot to add since i did it 2day.. when u grease all the spring, first 2 weeks, u will hear the spring moves a lot since its greased up big time but once it drys up after week-2 weeks, its so nice and quite and u dont hear anything.
Old Jun 26, 2010 | 08:44 PM
2000 CLK 320
How often do you have to grease up? Wonder what CLKMAN/FAN did because I believe I remember him saying that he has no noise/problems.
Old Jun 26, 2010 | 08:55 PM
i do it 2 times a year like every six months once.. *****, CLK live in CA while i live in VA and it snows like crazy and get wayyyyyyyyy below freezing and when sometime salt gets up there from the road, i got to grease it.....
Now if i was living in FLorida or California, No need to grease my car
Old Jun 26, 2010 | 09:02 PM
Ghostrider's Avatar
01 CLK 430
Yeah, I expected CLKFAN to chime in!!
Old Jun 26, 2010 | 09:11 PM
2000 CLK 320
He checks in every blue moon probably better to pm him on all forums, not that you are stalking him or anything. "NO HOMO" as Riley says in the BoonDocks...
Old Jun 26, 2010 | 10:09 PM
Old Jun 27, 2010 | 02:49 AM
Ghostrider's Avatar
01 CLK 430
Oh snap!!
Old Jun 27, 2010 | 04:01 PM
GiZzO's Avatar
CLK55 / E350 Coupe
one thing i would worry about over long usage is possible rust developing in that area due to metal to metal friction.
Old Jun 27, 2010 | 05:25 PM
Ghostrider's Avatar
01 CLK 430
Originally Posted by GiZzO
one thing i would worry about over long usage is possible rust developing in that area due to metal to metal fiction.
Oh yeah, good call on that one!
Old Jun 27, 2010 | 09:09 PM
that is why i greased it due to salt and rust
Old Jul 4, 2010 | 08:12 AM
NitrogenBalance's Avatar
none
Did this on my old C230, dipped the top 3-4 inches of coil(dipped one inch or so) into some rubberized truck bed liner. Two coats was pretty thick and worked like a charm, no noise or corrosion after two winters. Drop was pretty subtle with OEM springs.
Old Jul 4, 2010 | 10:56 AM
dlbehrns's Avatar
99CLK320,
BRILLIANT! I'll have a Guinness.
Old Jul 7, 2010 | 08:41 PM
Ghostrider's Avatar
01 CLK 430
