H&R with 19' rubbing?
i dont remember my wheel specs, but when i first got the my 19's 235/35/19 fronts and 265/30/19 rear fit find with the old falken grbs, now they rub with the new falken fk452 so much that i now run stretched, went down to 215s in the front on 8.5 guess it was too stretched so I bubble 3 tires on the front before going back to 235 since i had a pair of goodyears in the garage, but if i had to start from scratch again, I would run 225/35/19 front and 255/30/19 rear just to besure I wont rub. hope that helps, also research the forum, lots of tread on this matter
i'm sitting at no pads and i got 19 and got HR same one that u got. and im fine
it does rub if i bust u turn FULLY otherwise no..and it will rub if there is a deep dip in the road...
I got the kmac camber kit and that helped a lot and got my tires straight up and close to the fender.
i got also 15mm spacer in the rear but u might wanna roll the fender ($60) if u are planning to have people sitting with u.
when i had #1 pad all around, i did NOT have probs even with u turn but i wanted my car slammed so i took em off
u should be fine with your pads, but if want it lower, get pad #1 or 2.
your tires should fit as well as far as i know off
do u mean HR cup kit??? if so no i dont.
i got the HR aggressive and sitting metal to metal with no pad.
when i sit in the car, u dont see the tire, only the rim
btw i am on eiback prokit so my set up is different from yours...if you still want 245s in front...might be cutting it close
