vipclk320 stut bars
Old Aug 18, 2010 | 04:01 PM
Elzin's Avatar
clk 208
vipclk320 stut bars
was unable to send him private message, but had some questions on this.
here goes the message i tried to send him:
hi, just got the stut bars, was wondering if u have any how too's on how to put it on?
rear: will the bolt from the shock go down if i unscrew the bolt and if so what can i do so it wont?
front: drill hole only on drivers side?
easy access under the car? just remove the plastik from the wheel well?
what size are the bolts that came with it?
need to know how big the hole should be.
tyvm
Old Aug 18, 2010 | 04:27 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
tyvm
he is under CLK limited now.
i have all his stuff.
rear : just unscrew the nuts, put the bar and put the nuts on top of the strut.
front: u got to drill 1 hole on each side... just raise one side at a time and let the tire hang so u can have access the bolt when u drill the hole
U dont need to remove the plastic.
i just drilled the hole and i made it bigger till the bolt got fitted.
Old Aug 18, 2010 | 04:37 PM
Elzin's Avatar
clk 208
i tried just removing the rear nuts but the bolt just went deeper and deeper!
what size holes to drill?
any good pics showing were ppl drill this?
Old Aug 18, 2010 | 04:40 PM
what bolt??? u mean that piece of metal that stick out from the shock?????
dunno the size that i drilled..
but let me get u some pics hold on
Old Aug 18, 2010 | 04:43 PM
u move to that lil black box too, just remove one bolt from it and turn it
Attached Thumbnails vipclk320 stut bars-benzo-002.jpg   vipclk320 stut bars-benzo-003.jpg   vipclk320 stut bars-benzo-004.jpg   vipclk320 stut bars-benzo-005.jpg
Old Aug 18, 2010 | 04:46 PM
once u install em, u have to cut between the fire wall and where u see that big bolt , i had to hammer it down like 3 times so it does not hit the hood (when u try to close it), otherwise, it wont close.
if your ride is low as mine, you haveto cut teh bolt underneath the fender once you installed it, otherwise it will hit the upper arms
Old Aug 18, 2010 | 04:59 PM
Elzin's Avatar
clk 208
ty and its the bolt from the rear shocks, i unscrewed it but it just kept going further and further down! did not unscrew it fully due to i was afraid it would pop out of the hole and down in the wheel well.
do i need to jack the tyre up to add preasure to it?
Old Aug 18, 2010 | 05:04 PM
you are welcome and i really dunno. ask CLK limited and that is vipclk aka ash
Old Aug 18, 2010 | 07:14 PM
jbenz2001's Avatar
2001 clk 320
to install the front bars
1.find a drill bit that fits the hole on the black piece
2.align the bar where u want them installed,mark it
3.drill the holes
4.find some pipe to cut two pieces out of to make yourself some spacers so the bar can clear the throttle sensor.
5.go buy the bolts and nuts,make sure to bring the two spacers and a jack so u can make sure the bolts fit perfect.
6.after get n the right bolts and nuts,jack the car up and install.
The hardest part is preparing the install,installing is easy.
Now for the rear bar
1.find a way to precisely cut exactly where the strut is at,just a slit,or like I did a square.
2.take out all the trunk linen
3.I recommend taking out the first bolt to the strut cuz if u take out both its gonna be hard to tighten them enough to the point that ur strut doesn't make noise while driving.
4.after installing the bars carefully tighten the bars till u feel tension.
5.the rear bar is very delicate so as ur adjusting bounce the car up and down for any noise.
6.drive the car and make any adjustment till ur happy.now go have fun!
jbenz2001's Avatar
2001 clk 320
3.drill the holes
Old Aug 18, 2010 | 07:19 PM
jbenz2001's Avatar
2001 clk 320
Why did it post twice?
Old Aug 18, 2010 | 11:07 PM
dlbehrns's Avatar
99CLK320,
did you fart when you clicked you mouse?
Old Aug 19, 2010 | 03:21 AM
jbenz2001's Avatar
2001 clk 320
Lol,nope
Old Aug 19, 2010 | 04:22 AM
Williams707's Avatar
2000 CLK 320
Is this a mutiny?
Old Aug 22, 2010 | 04:38 AM
carbonducati's Avatar
2001 clk 430
I just installed mine in about 35 min, It is pretty simple.
Old Aug 22, 2010 | 01:17 PM
Elzin's Avatar
clk 208
so when adding the rear bar the bolt on the shocks will not just pop down threw the hole?
Old Aug 22, 2010 | 02:03 PM
2001 clk 430
No, The shaft is connected to the rear shock, you grab a vice grip an grab the top of the shaft and the use a 18mm end wrench to take off the nut. Once the nut is loose take the vice grips off and put the mount on and then do the reverse to take it off.
Old Aug 22, 2010 | 02:04 PM
2001 clk 430
ps, you can leave all the wheels on the ground,
Old Aug 22, 2010 | 03:53 PM
jbenz2001's Avatar
2001 clk 320
Yes the vise grip way is the way I did it.just be sure to take off only the top bolt not both.
Old Aug 22, 2010 | 06:12 PM
2001 clk 430
Did you do the cold air intake as well?
Old Aug 24, 2010 | 11:02 AM
Elzin's Avatar
clk 208
i did not, its a kompressor so i would need to make something very custom to be able to make that work. but i have seen others with the same engien type as me that has done this, anyone know of a person that has a worklog on making a open filter on the kopressor engien?
