how wide a tire can you go on the back
Old Sep 2, 2010 | 09:09 PM
rrich49132's Avatar
2005 c55
I am looking at 18 inch 2003 sl55 rims and the offset and such seem fine but the tires are 245 in the front and 285 in the back. Any clue if this would fit? My first thoughts are that 285 is too wide and it would rub in the rear?
Old Sep 3, 2010 | 01:07 AM
jbenz2001's Avatar
2001 clk 320
I have a 275/35r18 no problem.u should be able to fit 2 sizes wider.unless ur going for the stretched look then I can't help u there.
Old Sep 3, 2010 | 01:37 PM
Pauljay's Avatar
'00 Mercedes 430/55 clk cabriolet
I have 275/30/19 on the rear. 285's look like they'll fit too. I also run a 10mm spacer with the wheel arch liner taken out. I don't have my arches rolled and I've no rubbing.
Old Sep 3, 2010 | 02:20 PM
falls profet's Avatar
I've personally run 275/18/35s. That's about as far as I would go, especially if you're lowered.
And just as a side note...when I ran 225s in the front and 275s in the rear, my cruise control wouldn't let me go past 70 on the setting. Marcus has chimed in when I asked why it was doing that, and he said that at the speed that the ECU is reading from front/rear ratio in tire size is what was causing it.
Just be sure if you go anything over a 255 in the rear, Go with a 235+ in the front...
Old Sep 3, 2010 | 02:32 PM
rrich49132's Avatar
2005 c55
I think I am going to keep my rims stock and just get new tires. Not worth it to me to buy used rims and tires and spend over $1000.
Old Sep 3, 2010 | 02:53 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Its not the width its the diameter you need to watch in that case. Im not a tire guru but going 255 to 285 you'll need to drop the profile. Your tire shop shoulda caught that but id guess if you would have run 275/18/30s that may have "fixed" things for ya.. just food for thought
Old Sep 3, 2010 | 03:57 PM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
I had 265 on my rears and they rubbed on the inside tyre lining, but thats all dependant on the offset of course so dont get too worried. The other thing was that the large the tyre the smaller it makes the wheel look and can hinder the overlook. I personally like a little stretch to my tyres on my 9,5J rims and I have 255 x 35 x 18" but not made that you have a horrible ride. I have also stuck on some 18mm spacers to kick out the back and fill the arches.
Good Luck.
Old Sep 13, 2010 | 01:43 AM
c48wincup's Avatar
mercedes clk430 amg
help with tire sizing
I bought a 2001 clk 430 amg, it has285 35 19's on it and has a rubbing problem...the tires were brand new when i bought it in January and i didn't know there was a problem until i took it in for service and found that a chunk of rubber was missing and tires were about to go....is there any way to keep this size tire using spacers? i cann't afford to buy new rims and tires and i have to buy tires now...it has the chrome mercedes rims and i would really like to keep them on it...any help would be greatly appreciated.
