Need info/tips: Plastic weld to repair torn bumper cover.
Does anyone have any experience with this job ?
Tips on process, tools, materials needed ?
Experience with alternatives to welding ?
If you have something interesting to tell us about a fix Re. "grille insert", then it's ok with me if you post it in this topic--go ahead.
If someone wants to knock-off the AMG lower spoiler insert, then, for the sum of $4, buy some 3/4 inch, quarter round plastic molding at Home Depot, cut it to length, radius the two ends with sand paper, squirt it black with a rattle can, and screw it on with 3 stainless sheet metal screw. Voila, an AMG spoiler insert for $4.
To fix the broken other plastic parts, try JB Weld. I used it on a few parts that were damaged in the accident, such as the headlight assemblies and the radiator shroud, and it did the job. No problems after 6 months use /20,000 miles.
I'm going to buy an OEM genuine MB bumper cover, after shipping, around $500-600 at a couple of places on the net. Apparently, as I have learned, the OEM covers, like my damaged one, are made of polyurethane, and are not thermoplastic. What does the mean?
Thermoplastic bumper covers are made by blowing plastic beads into a mold, then using heat to form the bumper cover. This represents about 85-90% of all OEM bumper covers. About 10% of bumper covers, typically in the high end vehicles, like MB, are made of urethane, which is two compounds poured into a mold, forming a third compound, forming the bumper cover, without heat.
Thus, thermoplastic bumpers can be repaired with heat, using a plastic welder--welder costing about $200. Urethane can also be repaired using one of these home welders, but the technique is more difficult, requiring one to float the molten urethane rods onto the bumper cover, being very careful not to liquefy the bumper cover, as urethane, not being a heat formed material, will not melt, but bubble and liquefy.
So, I have chosen to buy a new bumper cover, rather than spring for $200, and risk liquefying my way into disaster, then buying a new bumper. I don't need the suspense. My Harleys are all the suspense I need Re. motor vehicles.
I want to thank you for your kind offer, and for your good info. I'm going with OEM on the bumper cover.
Again, thanks.
