front suspension clicking noise... need advice
Old Sep 12, 2010 | 11:54 PM
funky102's Avatar
2000 CLK 320
I changed out the front suspension on a 00 CLK 320 using eibach springs and bilstein shocks, and redid the bushings on the lower control arm and changed out the ball joints.
After putting things back together, I am getting this annoying clicking noise over speed bumps. To clarify further, the noise happens not when the suspension is being compressed (when climbing over the speed bump) but when the suspension is being uncompressed (the wheels have reached the top of the speed bump and are going down). I have to drive over the speed bump pretty fast to replicate the noise and it doesn't happen if I'm driving too slow. The noise also happens when driving over roads that aren't perfectly smooth.
I brought it to a shop and he suggested the lower control arm may have been damaged or the bushings may not have been put in correctly. I put in a replacement set of lower control arms, from a used car with low miles, and he said the noise/clicking lessened but it seems the same. He suggested the lower subframe was damaged because I put in the bolt the wrong way (I don't think I did). I'm not sure if I completely agree that its lower subframe damage, I hope it's not. Both wheels are doing the clicking noise.
Any help/advice anyone can give to figure out this mystery would be greatly appreciated!!
Old Sep 14, 2010 | 12:27 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
did u remove the pads ? that will make that noise too.(or the pad is notperfectly on).
do u have a kmac camber kit? if so that will make it happen since the bushing are poly and very hard and take some times to break em in..
Old Sep 14, 2010 | 03:10 PM
funky102's Avatar
2000 CLK 320
I did replace the rotors, I'll look into the pads and see if that's the problem. I'm hoping this can be fixed coz it's so annoying I'm ready to toss the car. Thanks for the tip. If anyone else has any other ideas, feel free to chime in.
Old Sep 14, 2010 | 09:51 PM
lseguy's Avatar
2005 c230
he didnt mean the brake pads he meant the spring perch pads.
Old Sep 14, 2010 | 10:11 PM
thank u
Old Sep 14, 2010 | 10:12 PM
No bro, not your brake pads.. i meant the pad that sit on top of the spring like this:
http://i315.photobucket.com/albums/l...8/CIMG8595.jpg
Old Sep 15, 2010 | 04:21 AM
funky102's Avatar
2000 CLK 320
aah, the spring pads. the brake pads didn't make too much sense but I thought maybe I didn't know something you guys did. Yea, I put a 1 dot spring pad on and I'm sure they were put on. I used packing tape to tape the pads to the spring while installing to make sure they don't move during installation.
And missed the other question, no Kmac camber kit installed.
Old Sep 15, 2010 | 09:27 PM
no idea then. take it to benz and ask em and they will tell u what it is then u do the work
