Violent downshift to 1'st gear at low speed deceleration (99 320)
Has anyone actually found the cause and fix for this problem or do we just live with this?
Is there any probs driving in W mode?
Any ideas?
N
I have a 99 CLK320 Sport and I experience these occasional violent downshifts from 2nd to 1st (and very occasionally violent upshifts from 1st to 2nd).
I believe I have got to the nub of the problem, apparently it is to do with the MAS sensor needing replacing.
Do a search of <mas* sensor> on the UK version of this forum at
www.mbclub.co.uk and read more.
I have ordered the new sensor and will have it fitted this week and keep you updated on progress, however it is intermittent so I wont know if this problem is resolved straight away.
Thx
Sasha
All you need is a size T10 torx screw driver, and a can of ELCTRONIC CONTACT CLEANER solvent.
I used to have a Rover 216 coupe (Honda engine and transmission) that also did exactly the same thing. No problems with the car after 5 years.
Don´t by the MAF from a MB dealer they will charge you aroud 500-600 USD.
I bought mine directly from BOSCH and payed 270 USD.
You schould be able to do the same i guess.
Or call BOSCH and ask how is the closest Distributer for the part you need and you schould get the same low prise.
The Partnumber of the MAF is: 280217515
(this is for the European CLK 320 but I think i schould be the same in the US other wise th PN is printed on the MAF)
Best Regards
Jonny Larsen
Transmission servos transfer cases, fuel pump sending units, crank shaft pullies, tie rods, lower ball joints, and self lvling systems all are failing at a rate I have not seem before. Make sure you have a warranty on these cars and haunt the dealer till they fix them. I finally sold mine when the warranty expired and got an X5. At the time I sold my 99 CLK I was experiencing the transmission problem, I had already had the fuel tank senders replaced, my crank pully was seperating and I had the lower ball joints replaced. The interior rattled from almost every panel and the dash in the center was making some strange noise when the weather got hot.
I hate to sound negative, but Mercedes quality is not what it once was, so keep your warranty up to date, I assure you if that crank pulley lets go it will be at least 2500.00 to fix, making a warranty easy to justify.
I used to have a 2001 BMW X5 4.4 and it had a reasonably logical shifter... If you were well into the redline, it wold not shift into the 1 gear... I've damn near hit the windshield a couple times getting used to it...
this is the second transmission--the first went out at about 70,000 miles. the transmission shop tells me that the gear position sensor is bad--which is causing high pressure in the transmission--which might be why the first transmission went in the first place.
anyone ever replace a GEAR POSITION SENSOR? the independent shop want $600 for it--
