CLK320 Won't start... I'm thinking CPS?
Old Dec 12, 2010 | 05:47 PM
alcool's Avatar
1999 CLK 320
Hi folks, my 1999 CLK320 with 130,000kms finally presented me with its first major inconvenience.
Been driving all day no problems, then stopped at the mall for about an hour. Came back to the car, and it cranks strong and steady, but doesn't start. Checked the fuel pump fuse and its okay. In my searches on here, am I right to assume it's likely the CPS? Waited a while and tried cranking again a few times, but same problem,.. After about 20 tries I don't want to kill the starter!
Thanks,
- Alex
Old Dec 12, 2010 | 06:37 PM
alcool's Avatar
1999 CLK 320
... and now I just tried it again after coming home from Sears with an E8 bit, and it starts like a champ. Still thinking the CPS should be changed??
Old Dec 12, 2010 | 08:20 PM
buffyclk500's Avatar
clk500
do u have a CEL come on
Old Dec 12, 2010 | 08:30 PM
alcool's Avatar
1999 CLK 320
No CEL... when it started back up it was like nothing had ever happened! Planning a road trip next week and do NOT want this to happen again on the interstate somewhere!!
Old Dec 12, 2010 | 08:45 PM
clk500
i did lots of cps and it u hook up a scanner it will read cps they cost around 40 on line
Old Dec 12, 2010 | 08:48 PM
alcool's Avatar
1999 CLK 320
Unfortunately I don't have immediate access to a scanner, but if my symptoms seem in-line with what a junky CPS would be, then I'm more than happy to just swap it out.
Seems like most people have prior issues with stalling rather than just flat out "not starting". I've never had any stalling issues, but maybe it was just a matter of time??
Old Dec 12, 2010 | 08:49 PM
clk500
i have done lots and it starts with not starting them it will stall
i would just fix it
Old Dec 12, 2010 | 08:57 PM
dlbehrns's Avatar
99CLK320,
as many miles as you have on your car just change it.
Old Dec 12, 2010 | 10:18 PM
Mslaughter's Avatar
Brilliant Silver CLK 320
Those symptoms seem consistent with a failing CPS; the car starts fine cold but hesitates when warm. I'd go ahead and change it.
Old Dec 12, 2010 | 10:48 PM
sinister55's Avatar
C55 AMG, BMW 535i, Mazda Cx-7, Nissan 240sx
Check battery and wires that lead to the cylinders. If it didnt start but you went back and i started it was probably cause it was heat soaked and electricity couldn't run through.
My battery was no good and heat soaked and refused to start.
Old Dec 14, 2010 | 04:19 AM
funky102's Avatar
2000 CLK 320
Sounds like the CPS. My experience started when I was parking so my car was running at low speeds and low revs then the car stalled. Same thing would happen when I would stop at traffic lighs as the car wasn't being revved high.
After stalling, I would need to wait like 20 minutes until the CPS cooled down for the car to start again. At that point, car would start like there was nothing wrong.
Old Dec 14, 2010 | 11:27 PM
alcool's Avatar
1999 CLK 320
Thanks for all the replies folks. Changed out the CPS today... will report back if it's still giving me troubles over the next few days!!
- Alex
Old May 22, 2011 | 11:10 AM
alcool's Avatar
1999 CLK 320
Few-months-later-follow up... was the CPS indeed. No problems since!
Thanks everyone.
