will 19" CL wheels fit on 430
Old May 6, 2003 | 01:52 PM
RichardCranium's Avatar
I tried to do a search on this but couldn't find anything.
Old May 6, 2003 | 02:32 PM
ViKTORiOUS's Avatar
W209 - W163
Yes, i have them on my CLK430, only they are the 2 piece ones, all you need to do is buy 15mm Spacers from H&R and of course roll out the fenders, then they will fit.
-Vik
Old May 6, 2003 | 02:33 PM
Petie's Avatar
2000 CLK430
D*ckhead ,
with proper spacers, yes. cant remember if its 10 or 15mm. Anyway, yes it definitely can be done without too much trouble. Looks great on the CLK. Good luck.
Regards,
Eric
Old May 6, 2003 | 02:41 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Yes it can be done
Yes it can be done with proper spacers, but it will not be a proper fitment.
This is because the CL uses 14mm lugs, the CLK uses 12mm lugs. The ball seat lugs used have different diameters. Therefore, the portion of the lug touching the wheel is very tiny, and also the hole for the lug is much larger (by 2mm or so). So not only is the wheel fastened improperly to the hub, there's a real danger of the lug pulling through the wheel if the wheel is ever given a hard sideways jar.
Two solutions are to either use an adapter that converts the 12mm to 14mm lugs, plus takes up the space for proper offset, or to redrill your hubs and rotors for 14mm lugs.
-s-
Old May 8, 2003 | 03:30 PM
SteveChod's Avatar
2000 CLK430 w/ 19"AMG rims
Definitely Works
I put it on mine. You need to get some custom spacers made up. Also need to make custom lugs. Were are you located at? Here's a pic of mine.
Old May 8, 2003 | 04:58 PM
2SYKbenz's's Avatar
those wheels look nice on the CLK
Old May 9, 2003 | 06:00 AM
SteveChod's Avatar
lugs
I had custom lugs made up for my car that were longer. The front lugs can be bought, but the rear had to be milled down to the right lenght. dazzmotorsports knows what there talking about with this. Call them up and you can get all the info from them. I called them up and then had it all made myself. I think they were charging about 600 for the spacers and lugs. If you do it yourself you can save about half that.
Old May 9, 2003 | 02:45 PM
I am in West Palm Beach Fla. SteveChod those wheels look great on your car.
Old May 9, 2003 | 03:19 PM
thuged_out's Avatar
this mine. i got everything from peter
Old May 10, 2003 | 10:10 AM
SteveChod's Avatar
nice!
I like it on black. your car looks nice!
Steve
