front bumper replacement
Old Feb 13, 2011 | 05:42 PM
rrich49132's Avatar
2005 c55
Guys,
I think I need to replace me entire front bumper. At the bottom of it you can see that I have broken pieces from the attached pictures and don't think I can simply glue them back together?
How much would a front bumper run and how hard would it be to find one already painted in black where I would not have to take it to a paint shop?
Attached Thumbnails front bumper replacement-022.jpg   front bumper replacement-023.jpg
Old Feb 13, 2011 | 06:50 PM
jbenz2001's Avatar
2001 clk 320
It just looks like ur missing ur inserts.just replace it wit mesh grill.its a lot cheaper then try n to get a hol of ur oem ones.
Old Feb 13, 2011 | 07:35 PM
sonnyhoang's Avatar
w208 CLK430, w212 E350, w221 S550
yeah once u get the center insert, u wont be able to notice the broken part. the center insert or diffuser is that piece that goes from foglight to foglight. i believe i saw dohcfiend selling one for really cheap. A body shop can reinforce the back and glue it back for ya with np tho.
Old Feb 14, 2011 | 07:43 AM
cindyclk's Avatar
You can usually find a diffuser for sale on ebay or the mb classifieds. If not, they are about $110 from dealer. Pay to have it painted or spray yourself. After it is installed, use a few platic zip ties to avoid losing it again.
Old Feb 14, 2011 | 12:17 PM
rrich49132's Avatar
2005 c55
Just got an estimate for $1400. When I looked at it I think I could get a dremel and cut off all those broken tops.
I am trying to find pictures of ones with a mesh grill and how it was installed but cant find anything. I would like it to look very stock and not too ghetto.
Old Feb 14, 2011 | 07:11 PM
cindyclk's Avatar
I broke those on my '99 430. I did a cheap fix that worked for 3 years. I slid a short piece of tubing behind the broken tab. I then used 2 small hose clamps above and below the broken tab. A small spray paint hid the clamps. When the diffuser was added, no one could tell. Cost abot $5 total. It beats $1400!
Old Feb 14, 2011 | 08:58 PM
rrich49132's Avatar
2005 c55
I don't think I could do that unless you showed me pictures of it.
I think I am going to try ebay and look online for a black OEM front bumper and hopefully can get at a reasonable price and swap it out.
Old Feb 15, 2011 | 12:39 AM
jbenz2001's Avatar
2001 clk 320
Most likley the bumper on ebay will be exactly how urs is no inserts.they usually just sell u the shell and u gotta put all of ur stuff on it.
Old Feb 16, 2011 | 08:17 AM
cindyclk's Avatar
I don't have pictures...Just feel behind the broken spots. You will find there is a hollowed verticle space about 1/2 inch wide. If you lay a piece of tubing into the space and then wrap a small hose clamp above and below the break, it will join the upper and lower together. I don't have the car any longer but it took about 30 minutes to do. You're going to look for another bumper and swap it out. If you are going to do that, believe me tat this quick fix is 100 times less complicated. If you are going to replace the bumper (which I have done twice on different cars), it will take you a lot longer and lots more $$ than trying this fix ....but do what you want to. You will still have to buy the diffuser.
Old Feb 16, 2011 | 09:45 AM
rrich49132's Avatar
2005 c55
Thanks will take a look over the weekend. Any suggestions as to the diffuser as to where to purchase and how does it get secured to the bumper?
Old Feb 16, 2011 | 03:52 PM
cindyclk's Avatar
Here is what you're looking for...center tow hook cover/diffuser.
https://mbworld.org/forums/clk-class...part-find.html
part #2088850022
$91 http://www.mbzwholesaleparts.com/par...&siteid=215317
Old Mar 17, 2012 | 04:10 PM
jkiddd33's Avatar
2005 E55 AMG
fron bumper w208
Originally Posted by rrich49132
Guys,
Are you still looking for that bumper?
I have a black amg bumper for sale.
Old Mar 17, 2012 | 09:49 PM
dlbehrns's Avatar
99CLK320,
You might want to send a pm or an email. the last post is over a year old.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
