check strap issue
Old Mar 31, 2011 | 02:12 PM
W2O8TC's Avatar
W208
check strap issue
Upon research, looks like my check strap is shut on the drivers side as my door swings open without 1,2,3 stop and my window only opens halfway. I found a great deal online on part and found how to remove door panel under "search". My question is, does the battery need to be disconnected to remove the door panel? I read some ways disconnect the battery and some don't. can I get through the front speaker opening to get to the check strap? How will I remove the broken check strap pieces? I couldn't find dyi on check strap so any help will be appreciated. Thanks
Old Apr 1, 2011 | 12:11 AM
Ruination Fan's Avatar
02 CLK430
You should be able to get it out through the opening for the windo regulator, if no the speaker can be removed and accessed that way. There are the two 10mm hex bolts holding it from the outside, and one 10mm hex bolt holding it on the inside (behind the plastic sheeting once the door panel is removed).
Old Apr 1, 2011 | 09:24 AM
W2O8TC's Avatar
W208
That's more clear. Thanks!! I ordered the part today so it should come next week. How about the battery? Should I disconnect? I forgot to mention that my cars going into the shop for srs. I have srs warning on my dash which keeps my srs turned off(I assume) until the warning light is fixed. With this in mind, still disconnect the battery? Thanks a bunch for you help!
Old Apr 1, 2011 | 07:56 PM
02 CLK430
You should be ok since the SRS system is shut down due to a fault in the system (maybe passenger recognition sensor?), but if you want to play it extra safe, just disconnect the ground from the battery.
Old Apr 1, 2011 | 08:00 PM
W2O8TC's Avatar
W208
Thanks a lot! I will update the thread once I am done.
Old Apr 22, 2011 | 11:39 AM
W2O8TC's Avatar
W208
I replaced the strap and yes, it was a faily easy diy thanks to all!
Shop told me the SRS light is due to child/passenger seat recognition sensor within the seat and it will cost $600 to fix, mainly for the labor since the seat upholstery have to be taken apart to get to the sensor. I didn't get it fix at the shop yet. Does anyone have a part # to this sensor and diy instruction? I appreciate any help on this. Thanks!
Old May 10, 2011 | 06:23 PM
ludikrous's Avatar
2002 CLK 55
Instructions
I have the same problem, broken strap!! Can you forward the instructions that you used to install new strap? I would appreciate it.
Old May 10, 2011 | 09:23 PM
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
Read this tread first - https://mbworld.org/forums/clk-class...oval-help.html and then this - https://mbworld.org/forums/clk-class...oor-strap.html
