Question for people with 20's on their CLK
Old May 18, 2003 | 06:33 PM
ibcre8nhos's Avatar
Did you do any modifications to get the 20's on there, what are the set backs, can you lower it, cna you jsut give me all the info about having 20's on your CLK because i am trying to put them on my CLK 430 thanks
Old May 18, 2003 | 07:04 PM
ViKTORiOUS's Avatar
W209 - W163
You have to roll out your fenders, it depends on how low you drop the car. Youll get A LOT of rubbing, but if you want the look go for it. Also the ride might be a little harsh, i have 19's. The look huge (AMG CL rims) when spinning, people ask me if they are 20's. But ask Dronollis about this info, hes the only one on the forum that has or had 20's on his CLK, now that he sold it.
Felix, what car are you driving now?
-Vik
Old May 18, 2003 | 09:48 PM
dronellis's Avatar
EUropean Freaks
Re: Question for people with 20's on their CLK
Yes 100% you need to roll the fender and also it depend on how low you wanted to drop it...if it just changing the H&R springs you dont need to roll the fenders. but if you cut it 1 coil or more you need to roll it more or custom flare fender...
Get the exactly offset for CLK and you will save the fenders...trust me It need to do alots of works...but good luck dude..
Old May 18, 2003 | 09:58 PM
ibcre8nhos's Avatar
dronellis, i just sent you a message, i need to talk to you and ask you a couple more questions so can you e-mail me at ibcre8nhos@aol.com or instant message me at ibcre8nhos on Aol
thanks
Old May 20, 2003 | 04:45 PM
dronellis's Avatar
EUropean Freaks
I drove 02,325 ci conv
-Vik
Old Feb 15, 2007 | 05:46 PM
CLK FAN's Avatar
2000 CLK 3.2
I need your help with some questions regarding the H&R CUP KIT and running 20x8.5 and 20x10 with 225/30/20 and 255/30/20.
All of my fenders are already pulled and rolled to the max because my car is super slammed right now with cut Brabus springs and 19's but I wanted to raise it up to fit the 20's. Thanks.
Read my post:
https://mbworld.org/forums/clk-class-w208/182018-h-r-cup-kit-20x8-5-20x10.html
Old Feb 15, 2007 | 06:28 PM
Arabian Knights's Avatar
you dont need to roll out your fenders if you are going with 20 x 8.5's, i have 20's and lowered with eibachs, no rubbing at all. Unless you put 255 tires in the back then you wont have any issues. Really all depends on the setup.
https://mbworld.org/forums/attachmen...4&d=1147371685
Old Feb 15, 2007 | 07:09 PM
CLK FAN's Avatar
2000 CLK 3.2
How about with a 20x10 on the back with 255/30/20 with a cup kit set up? Do you think the 255/30 will stretch enough to fit with no problems or should I go extreme and stretch a 245/30 or 245/35 on a 20x10 wheel?
Old Feb 15, 2007 | 08:41 PM
there was another guy at the shop with the cup kit and attempting 20x10 with 245 and they couldnt do it, plus you are gonna have a hell of a ride, i suggest 19's with a good lip and some big tires, i have 20's with 225 which barely fit and its lowered. Cup kit really drops the car and you can only roll the fenders out so much. If you take it to a good shop, slip them some extra dollars and let them play around with it to see what works, like i said 19's will give you a lot less problems if you want the huge tires in the back.
Old Feb 15, 2007 | 11:56 PM
CLK FAN's Avatar
2000 CLK 3.2
You think even if I go with the biggest spring pads and an extra pad on the bottom of the springs?
Old Feb 16, 2007 | 04:36 AM
it comes down to trying it out, but yes i still think you'll have an issue.
Old Feb 16, 2007 | 09:24 AM
CLK FAN's Avatar
2000 CLK 3.2
well the wheels don't come until March 9th so I guess I won't know until then.
I'm going to install this cup kit with the #5 pad up front and #4 in back with #2 pads all around the bottoms of the springs with a 225/30 up front and a 245/30/20 stretched out to the max on the 20x10 and see what happens.
Old Feb 18, 2007 | 02:02 PM
mortenso's Avatar
CLK200
Did you order the AMG styling 4 rims in 20" staggered setup, with ET32 front and ET37 rear? Been looking at these wheels for a while, I really want these in 19" staggered setup but they are only available with the big 3,5" rear lip on the 20x10 wheel.
Old Feb 18, 2007 | 02:10 PM
CLK FAN's Avatar
2000 CLK 3.2
No...I ordered the Sevas S-55 in Black. This one has a 4" lip and comes in Black, Silver or Chrome and the best part is that the lip is chrome on all of them and not polished aluminum like I have had in the past with 2pcs wheels that you have to polish every week. The wheels are really nice in person...very sporty and not blingy. It resembles the Iforged classic or the HRE 547...it's split five spoke with rivets.
Here's the link, but they look much better in person:
http://sevaswheels.com/s_55.html
Old Feb 18, 2007 | 03:10 PM
mortenso's Avatar
CLK200
mmm nice wheels. Did you order them with offset ET40.
What kind of spacers are planning to run front and rear.
Old Feb 18, 2007 | 03:27 PM
CLK FAN's Avatar
2000 CLK 3.2
not sure yet...I'm leaving that up to the shop I'm getting them from. They are going to be responsible for making them fit right.
But I would assume or guess a 5mm in the front and an 8mm on the rear.
I'll be posting pics first week of March.
Old Dec 29, 2024 | 11:14 AM
Dan R's Avatar
2000 clk 430
hey will 245 35s fit on 20x9.5s in the rear
