Really Need Some Help Stuck In Bad Situation
Basically the car won't shift out of first. We replaced the transmission shift module, electric board for valve body and shifter along with transmission connector and o-rings and car does not shift out of First. When we first changed the ecu control module it shifted for about a week and than burned out because of a short. We fixed the short and replaced the ecu and this time no shifting took place. If anyone has any ideas or any feedback it would be hugely appreciated. This is extremely time sensitive as I am trying to move off the island and need to sell the car ASAP.
Its a tiny url...
It does work it goes to a page where you click proceed to page.
This is the long link it goes to...
http://www.eanswer.com/mercedes/?r=p...FcJP4QodeW54_Q
(And thanks...)
how about reseting adaptation values? so ecu doesn't think it is still in limp mode?
just want to make sure we are on the same page, you replaced the gear shift assembly sensor (possibly fluid spilled in there) and the speed sensors on the conductor plate?
Pannyman: we have not gotten 0 codes and no lights are on.
Insame1: We bought brand new unit that was tested as far as I can tell.
what about the sensor in the gear shifter area? peopel spill drinks where you put the cup holder.
make sure the adaptations are reset and that its not in limp mode still...
1. shifter is brand new
2. we dont have a dip stick it is broken
3. can they check the required amount should be in quarts
4. we will scan for codes and reset
its not about the codes, its about hooking up the stars mercedes software laptop to your car and reseting adaptations and making sure to take it out of limp mode.
is this just a regular mechanic or a merc indy mechanic? if you can get a mechanic to plug up the star system to your car, you may be able to find the root of the issue..
does the trans computer store old codes
does the ECM store any transmission codes that may trigger limp mode
does any ecm record faulty sensors on valve body or any transmission issues
what else may cause transmission not to shift out of 1st gear if we have, new shifter, ecm, and electric plate on transmission valve body
any idea how may quarts the transmission takes if you just do a trans pan gasket and the converter is still intact.
you've basically replaced just about everything you could in regards to the transmission unless your transmission took a dump, in which case the mech should be able to diagnose...
i think total transmission fluid capacity is about 8.5-9 quarts but you can not drain all, the most that comes out from a transmission fluid change via conduct plate or filter is about 4 quarts....you really need a way to measure, transmission is sensitive to fluid level.
722.6 dipstick is 1220mm long, which is about 4 feet. go to closest hardware store and buy 4-4.5 ft of 1/8" steel cable (galvanized) which is very flexible and use that as a dipstick. when fluid is fully hot the level should be between 55-65mm from the bottom of the cable, so you might want to put some colored tape between 55-65mm from the bottom of the cable. fluid is checked when tranny fluid is fully hot (car has been driven for at least 20-30 min), car is left RUNNING, put in PARK, and check on leveled surface. make sure the cable is touching the bottom when checking the fluid, try it several times.
What Is Limp Home?
Well, that means, your car has lost a wheel so it is driving on three wheels to home.
Seriously, when the Electronic Transmission Control module (ETC) detects intermittent or active problems, it prohibits gear shifting, in order to avoid serious transmission damage.
There are two different types of Limp Home modes, depending how serious the problems are. The names of these two different Limp Home modes may sound counter-intuitive but that is what Mercedes used.
Mechanical-hydraulic emergency running mode (This is the light duty Limp Home)
In this Limp Home mode, the transmission locks onto the 3rd gear or the last known “good” gear.
This particular Limp Home mode can be reset by turning the ignition off and then on.
This mode could set generic OBD II code and also intermittent code in the ETC.
Electric emergency running mode (This is the bad boy )
In this Limp Home mode, the gear engaged at that time is retained and the assigned fault code is stored. After a shutdown, wait for more than 10 seconds, and restart, the transmission is locked in the 2nd gear and reverse gear only. When the shifter is moved from “P” to “R” or “N” to “D”, there is a huge clunk.
The transmission will be in this mode until the codes are cleared from the ETC by Mercedes HHT (Hand Held Tester) or SDS (Star Diagnostic System) or some third party special scanners or even the reversely engineered ones. Generic OBD II scanners cannot clear these codes from the ETC (although they can clear the corresponding generic OBD II codes).
When the transmission is in this “electric” Limp Home mode, it feels like it is completely shot. Many times (actually I will go out the limb and say most of the time) you do not need a rebuilt transmission or a new ETC.
What to do if the transmission is in limp home mode?
The most useful thing to do is to have the ETC trouble codes read. This requires a Mercedes HHT (Hand Held Tester) or SDS (Star Diagnostic System) or some third party special scanners or even the reversely engineered ones. These codes are pretty accurate at pointing to the fault that caused the limp mode. For example, it may have codes for speed sensors or the shift module.
If no Mercedes scanners are available, at least try to read the codes using a generic OBD II scanner. The generic OBD II codes are not as precise as the proprietary Mercedes codes but they might shed enough light to have a good enough diagnosis. For example, if a code P0715 is read, then it is fairly certain that it is caused by the speed sensors.
After fixing the underlying cause of the (electric) Limp Home, the transmission would still not shift. The ETC has to be reset (codes cleared) before it will act normal again.
Without an ETC reset, people often (unnecessarily) replace the ETC. Of course, a new or working ETC will make the car shift again but all is needed to be done is to clear the codes in the ("bad") ETC. When the ETC goes into (electric) Limp Home, it shuts off all the power to the solenoids so the ETC will test "bad" because of this.
There are different versions of the ETC and certain ETCs can only work with certain valve bodies so exercise caution when replace either the ETC or valve body. It is a good idea to use the existing part numbers to find replacements.
So if you have a 2004 CLK 320 be ware and maybe you should just spend a few hundred and replace this part before it fails on yours! MB USA said the is no recall for this part but it seems like a common problem. After a quick search online I found a lot of people who had the same thing happen to them.
