Best ride quality on lowered springs/shocks??
I think I finally want to take the plunge (no pun intended) and drop my car!! But I do have a few questions....I know I don't want to go as low as the cup kit, and it seems everyone loves H&R/Koni....
1. What combo of springs and shocks will give me the best ride?
2. Will I experience any 'bounce'?
3. Where should I buy from?
4. Any installers in Houston?
5. How much should I expect to spend total?
6. I'm running 19"s, will my tires wear quicker?
Thanks for all your help guys, I'm very apprehensive as I have seen too many botched drop jobs!
but I believe Kleemann would be a good choice in ur case
FW :
KLEEMANN Suspension Systems
The KLEEMANN Speed Sensitive Sport Suspension systems utilize CNC precision wound springs that are shot peened, phosphate treated and powder coated. They are true progressive rate springs, providing a comfortable ride while reducing body roll and lowering the vehicles center of gravity.
Giving the car the ultimate in handling are the very innovative Speed Sensitive dampers, providing performance unlike any other damper can offer!
High pressure nitrogen gas charge and Variable Aperture technology allows the KLEEMANN damper to have a variety of compression and rebound rates. The quicker and farther the damper is compressed, the stiffer it becomes.
The end result is a suspension that performs like no other, giving a comfortable ride on the street, while providing unmatched handling dynamics during spirited driving.
I just copied it from http://www.evosport.com/product/susp..._mercedes.html
well , the price of the Kleemann 4 Speed Sensitive Sport Dampners is quite expensive , costs $1,680 from Evosport
however , heard that ppl is very satisfied with it
for me , I would take it if I could afford
hope this help
well , how about koni yellow shocks + H&R sport springs ?
the H&R sport springs lower F 1.4" and R 1.3"
http://www.hrsprings.com/site/frameapplications.html
Koni adjustable shocks from www.tirerack.com $400
I have the koni's in the softest setting. For the best ride...that depends on your taste, with the koni's you can adjust them to your like.
For installation, any reputable body shop will do the job.
As for you tires, they will last longer with the camber offset.
Hi , that means if i set the koni shocks in the softest setting , then it wouldnt be too hard , rite ????
but does it affect the height ????
also , what is the camber offset ? sry that i duno about it .....
thank you
Will lowering with H&Rs require me to roll my fenders with 19"s?
Also, can any reputable shop do the alignment and camber adjustment?
TIA - Again!
-nickv
r u going to use the h&r cup kits for ur car ????
I think i will do the alignment in Benz dealer , it costs more , but i think it is worth ......
