can any 1 supply this part for me ??
Rating: Thread Rating: 2 votes, 5.00 average.
Old Nov 27, 2011 | 07:53 PM
russ973's Avatar
clk320
.PART NUMBER ; 208 540 05 11. need a replacement or have it fixed, CAN ANY 1 HELP CAN it be fixed ? 1 return email from a tec-shop said this 1 can not be fixed/-the digital window looks like a shopping item bar-code (unreadable) THE cluster has 1 center window (digital read out )as you find in the e/class type; ; not the 1 with 3 digital windows;
Speedo cluster part number: 2085400511
Make MERCEDES BENZ
Mod CLK 320
Eng: 3200cc
Fuel type: PETROL INJECTION
Body type: COUPE
Year: 2001
Old Nov 27, 2011 | 10:20 PM
dlbehrns's Avatar
99CLK320,
If you are in the US there are places to fix a digital speedo. Do a google search and you will get several hits like http://www.instrumentclusters.com/
Old Nov 28, 2011 | 12:14 AM
russ973's Avatar
clk320
speedo problem
im in australia and was told they can not fix this type of speedo cluster quote, The type of cluster you have is unfortunately not repairable. Part: Speedometer
Make: MERCEDES
Model: CLK 320
Engine size: 3200cc
Body type: COUPE
Year: 2001 PART NUMBER ; 208 540 05 11
Transmission: 5 SPEED AUTO can you fix it -the digital window looks like a shopping item bar-code THE cluster has 1 center window (digital read out )as you find in the e/class type; ; not the 1 with 3 digital windows
Old Nov 28, 2011 | 02:14 AM
sonnyhoang's Avatar
w208 CLK430, w212 E350, w221 S550
i think if u check on ebay, you can find some pretty good priced clusters. Goodluck
Old Nov 28, 2011 | 12:05 PM
slobodan's Avatar
1999 CLK 320
Found this hope it helps...
http://www.fbt-parts.com/?index=defa...13d26&lang=840
Old Nov 28, 2011 | 12:15 PM
LAWYER2's Avatar
15' W222
Originally Posted by slobodan
thats for a pre-2k model, unfortunately it won't work
Old Nov 28, 2011 | 06:45 PM
russ973's Avatar
clk320
thanks
im waiting for reply from them ! it is the 1 im after thank you very much slobodan ;hopefully i can get my hands on it !! sense it looks like they can not fix the 1 in my car ..
Old Nov 28, 2011 | 07:46 PM
russ973's Avatar
clk320
y
y is that !!!.. the part number is a match,-- as fair as i no;-- if the part number is the same;-- it,s the same; .--. should not make any difference when it is fitted ?????????????? fitted in 1998 or 2001 photo is right, the part number is right ? do me !!! unless you no better ?
Old Nov 28, 2011 | 07:52 PM
russ973's Avatar
clk320
yes but
i have looked e/bay-- but still no matching part numbers !!!!!!!!
Old Nov 28, 2011 | 11:53 PM
Ruination Fan's Avatar
02 CLK430
Give BBA reman a call/e-mail.
http://www.bba-reman.com/us/index.aspx
Old Nov 29, 2011 | 02:10 AM
sonnyhoang's Avatar
If you're looking for a cluster, here you go. Goodluck
http://www.ebay.com/itm/MERCEDES-CLK...#ht_705wt_1163
http://www.ebay.com/itm/MERCEDES-CLK...#ht_500wt_1156
http://www.ebay.com/itm/SPEEDOMETER-...ht_1735wt_1396
http://www.ebay.com/itm/Speedometer-...ht_1781wt_1396
the part #'s are barely off by liek 2 digits but iduno if thats because theyre from different years or not, but good luck!! type clk cluster as the keyword for the search
Old Nov 29, 2011 | 07:27 PM
russ973's Avatar
clk320
y
[quote=sonnyhoang;4937018]If you're looking for a cluster, here you go. Goodluck can any 1 tell me y my speedo cluster digital read out looks like a bar-code on a pack of cornflakes ect; as all the 1s i hear about only have missing of blank picsells
russ973's Avatar
clk320
Old Dec 1, 2011 | 01:59 AM
russ973's Avatar
clk320
Mercedes have now told me my cluster has been superseded to 208 540 29 11
Old Dec 3, 2011 | 11:42 PM
Pancho's Avatar
2000 CLK430 Cabriolet
I agree w/ ruination. Contact:
BBA Remanufacturing Inc., 300 Myles Standish Blvd., Taunton, MA 02780, (866) 573-2740, us-sales@bba-reman.com, www.bba-reman.com
Fixed my cluster for $245, lifetime warranty, on May 2008. No Prob.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
