Benz dealer diagnosed my car, are they rite?
Old Apr 4, 2012 | 02:08 AM
krayzie_e99's Avatar
2000 CLK 320
sup felas, my clk has intermitingly stallin on me. alrdy replaced fuel pump, filter, n relay, cps, egr valve myself and it still dyin on me. finally took it to dealer and they sayin it i need a new intake manifold and air mass sensor. ther no CEL and sensor was replaced under a yr ago. my question is wud a bad manifold cause my engine to die?
Old Apr 4, 2012 | 10:50 AM
CLK55_NYC's Avatar
2001 CLK55,2003 CL55AMG,2003 E55,2004 CLK55,2011 E350
if its cracked and letting air in, sure.but how would that happen.. its just a big piece of cast aluminum. I think they're scamming u
Old Apr 4, 2012 | 12:32 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I would say no on the manifold but was the MAf OEM? if not they normaly last about a year from what I have seen
Old Apr 4, 2012 | 03:35 PM
2000 CLK 320
actually the MAF was from ebay, not a bosch. but thers no CEL...
Old Apr 4, 2012 | 05:02 PM
MarcusF's Avatar
2002 CLK430
If the 320 uses a two piece magnesium manifold that's simular to the 430/55, and it's leaking, thats it. The problem is, the dealer doesn't have a gasket for the upper/lower manifold halfs. You can try removing it, disassembling and cleaning it, and then attempting to use silicon or something, but I'vs only read of a few who have gotten the seal to hold.
Personally, I'd call a junk yard and ask for the intake. As for the MAF, it's easy on a 430/55 and even easier on a 320.
Old Apr 4, 2012 | 09:44 PM
dlbehrns's Avatar
99CLK320,
what process did they use to diagnose the leak. never heard of anyone on this forum with that problem and I've been her since 07. Marcus, what is the likelyhood of a cracked manifold? leaking possible but cracke?
Old Apr 5, 2012 | 12:43 PM
2000 CLK 320
il be pikn up my car today and talk to advisor, they quoted me at 2600. i said no thanx lol
Old Apr 5, 2012 | 07:39 PM
2000 CLK 320
just got my car back, all i can say is WOW, these benz services advisors are SHADY!!so advisor is telln me i need intake manifold and MAF and says thats whats causing my engine to stall, so i suggested i start off wit the MAF since its the cheapest. he INSISTED i do manifold first, at price of 1200 just for part. and said dont even bother with MAF cause with bad manifold it be a waste of money.
so today when i pick up my car, i tell the advisor if he can show me himself where this crack is on the manifold. he introduces me to mechanic whos been workn on it. so while advisor has a phone call he has to take, im askn questions to mechanic and he tells me that the MAF is whats causing my engine to stall. the bad intake is just giving me a rough idle at intermitten times. i was like wtf, thats not what advisor told me,lol. so i just paid 175 for a diagnosis. i got the Truth from mechanic, he said a new MAF would fix my problem of stalling, which is y i took it in the first place. i dont expect my car to have a perfect idle since its a 2000 clk with 200k miles. lesson of the day, dont trust these service advisors, they just after your cash. im glad mechanic was honest. gona order a MAF from autohause az, hopefully mechanic is right! lol
Old Apr 5, 2012 | 08:59 PM
Silv430ClkR's Avatar
2002 Clk430
I hope so too. A bad maf will give a rough idle and can cause the car to stall BUT a crack in the intake can produce those same symptoms. Better to start with the cheaper parts first and work your way up to the more extensive and expensive parts if need so. Just incase, If it is the intake thats giving you the problem and the crack is easily accesable, there are welding rods for welding aluminum and would be a hell of alot cheaper solution to replacing.
Old Apr 5, 2012 | 09:33 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
i think for manifold they got to do that compression test.. My mechanic did it on my car and they thought it was leaking but it was not!!!!anyhow yes dealership is a rip off .
, my car used to hesitate at 5000 rpm and they quoted me $4000 because htey have to start from scratch and fix everything.
even though the diag tools shows all wires and so forth are good to go.
i ordered new plugs and new wires and did em in front of my house and no prob since...
Old Apr 6, 2012 | 01:38 AM
MarcusF's Avatar
2002 CLK430
The manifold is magnesium. It's not going to crack on it's own. Its a non-stressed part that just sits there. Some people have claimed leaks but most of the time its because they've taken it apart to clean/HP tricks. There was one guy either here or on BW whose 430 manifold leaked on its own. He said he never took it apart.
Old Apr 6, 2012 | 02:19 AM
2000 CLK 320
ive never took mine apart for anythng. i have yet to see a crack anywhere as well. while i was at dealer they sprayed somethng on the front of the intake and the idle speed changed....
Old Apr 6, 2012 | 01:53 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
That would indicate a vacuum leak. There is a vacuum line in the center front down low.. id check there also for the leak. May not be the manifold
Old Apr 6, 2012 | 05:11 PM
2002 Clk430
Yea probly just a line. Test it out on your own using a can of starter fluid, spray around the area they sprayed to try to pin point the location and do what ever nessecary to fix it. Dont go nuts with the spray and spray the crap out of everything lol! Its definately a vacuum leak if the idle changed while spraying. Take off any engine cover you have on it while testing. Good luck!
Old Apr 7, 2012 | 12:17 PM
2000 CLK 320
thanx fellas, much appreciated! MAF sensor on its way, il install nxt week. hopfly that fixes the stalln problem
Old Apr 10, 2012 | 09:58 AM
Norman2's Avatar
2000 CLK320 coupe
Hi, I believe you should also have the Crankshaft Position Sensor replaced. I own a
2000 Mercedes Benz CLK320 and mine started to not only stall but it would
turn off while driving. I let it sit for about fifteen minutes and then it would start again. The motor would turn but would not start. On this forum someone mentioned the Crankshaft position sensor. Replaced and no more
problems. Maybe that is your problem. Regards
Norman2
Ps. It is also a very non-expensive fix and you can do yourself. Part costs 75-100$
Old Apr 10, 2012 | 04:01 PM
dlbehrns's Avatar
99CLK320,
I took mine in for an alignment after changing to lower springs & sport shocks at 30K. the service mgr told me my lower control arm bushings were shot and my valve cover gaskets needed replacing. "At only 30K" I asked. Yeah, he said. NOT I said.
Old Apr 13, 2012 | 02:22 PM
2000 CLK 320
put in new MAF and car running like a champ now! sucks i had to spend over 1k on fuel pump,filter, egr valve, and cps when that wasnt even the cause of engine shuting down on me. o well, jus know that a bad maf doesnt always throw a CEL cuz i never got one, thats y i didnt thnk it was maf. i thnk crack in manifold is bull****, im not ona fix that until i really need to...
Old Jun 10, 2012 | 05:15 PM
2000 CLK 320
a month later after new MAF car still died on me and had CEL. local shop said it had vacuum leaks, over 1k to fix. car has 200k miles so i had to say goodbye. sold it to carmax for 2gs. now its eitha gona be a newer bmw or benz cls. this gave me a sour taste for benzes so i might go with a bimmer. anyways i am selling the 19 in brabus replica wheels with tires, hit me up if interested...
Old Jun 10, 2012 | 05:23 PM
2000 CLK 320
pic
Attached Thumbnails Benz dealer diagnosed my car, are they rite?-img_7267.jpg
Old Jun 10, 2012 | 07:23 PM
CLK55_NYC's Avatar
i wouldnt hold a grudge against the benz 200k miles is a lot.. The dealer.. well, thats another story.
