CPS? Car starts but shuts right off
i try again a few days later and it turns over but shuts right off...and keeps doing it until i get lucky and it may stay on...i go for a little drive and it stalls at idle...
ive already tried cleaning the MAF and it made 0 difference so can this be the CPS or probably something with my messed up custom turbo? lol how can this just suddenly happen when the car was running completely fine? i just didnt use it for 2-3 months and this started suddenly occurring
Cleaning the MAF usually does very little from the maf threads. Usually the symptoms are very rough idle and severe hesitation.
The repeated dying sounds like a cps.
but saying that...custom turbo?
that's what i thought anyways...
i have a CEL b/c no cats but ill see what codes come up
I am currently dealing with a similar problem, what happen in my case is my car start normally, i reached the first red light, then it died...Started back up again and it did start. Second time i drove my car, same thing except it took 2 min to started back up again, and the engine light came one...The Third time, same thing except it never started again...that was 3 weeks ago...I've been troubleshooting it since and now i am really desperate and don't know what else i can do other than scrap the car...
When we tried to read that error, it said clearly crankshaft position sensor, so first thing i did was to buy a new part and replace it. (My initial CPS was stuck and broke as we tried to take it out so i had to remove the tranny and break the part out ...)
However the car would still not start, the engine light did not clear out, and still said CPS...The dealer thought there was a GAP between the sensor and the Flywheel, but no such thing as a GAP the Sensor is magnetic and it holds on the flywheel as it should...The 2pin Cable that send the signal of the CPS to the ECU is fine...
Using MB star software, we tried to read the RPM by manually spin the engine but 0 RPM came...so we thought the ECU is not getting the signal sent by the CPS, until we discovered while checking the drive authorization, it said Specified value: ''Immobilizer is activated''; Actual Value: ''Immobilizer is activated''...we tried to turn off the Immobolizer but it seems the car is not allowing us to change it...
So in other words, it seems the ECU is purposely not allowing me starting my own car...
I have no idea why this is happening and above all i have no idea how to fix it...Anyone knows why ? 2001 CLK320
What is a MAF ? and CEL?
Sorry i simply meant i space between the sensor and the flywheel...they put a mirror and came up with this idea...They wanted to charge me $1200 to remove the tranny again...cuz my sensor was stuck so i said Hell no...
I manage to remove that stuck sensor myself without removing the tranny...I have tried 4 different CPS in this car...3 were after market, the last one was 1 sensor from the dealer ship, I can clearely see the flywheel when i remove the CPS and when i put it back in sometimes i put it soo deep that i feel it hitting the flywheel. I even made sure the magnet from the CPS engage with the flywheel before plugging the wiring harness back and screw the sensor but no luck starting it...I've 3 different specialist diagnostic the car including the dealer, spent close to $2000 in 3 weeks and no one can give me a Clear answer and FIX it...and the best diagnost so far was my friend only charge me 50$ to tell me the immobilizer is on...I even have a print screen from his MB Star (Same software used by the dealer)
I've spent all night searching about the Immobilizer, and apparently if the computer think the key is sending the wrong code, it activates thus not allowing the fuel to get to the engine, although the car Cranks...Worst is the ECU lets the key unlock the door, and put the ignition on, but wont crank...I found a website that seems legit and for now that's my only lead...
http://www.autokeysquad.com/lost-mer...ob-replacement
I'll let you guys know if it actually works if i do it that way...
