How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.
Subscribe
Jan 11, 2013 | 12:33 AM
Hello All,
Over the past 6 months i have been contemplating what i could do to spruce up my interior. I felt as though my interior became lifeless and was growing quite dull with each passing day. The mixture of light grayish white interior(Carpet and Door Panels) was quite difficult to keep clean and required regular vacuuming and occasional de-greasing to rid the tough stains.
Frustrated, that i was, i decided to treat my girl (Mercedes) with a little make up for her Christmas. Additionally i must say she is an engineering beauty but naturally over the years beauty will fade. Shes now 14 years old and the time came for her to look young again.
Attached are some pictures with relatively simple steps, totaling 3-4 days that i have used to rejuvenate,replenish and remodel my interior.
Step 1: Acquire your desired paint (I bought 8 cans of Dupli-Color HVP100 RED Vinyl and Fabric Paint),400 grit sandpaper,alcohol,Stiff Scrubbing Brush, Painters Tape along with disposable Gloves and a clean microfiber towel.
This is what my interior looked like with the fading paint.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc00977_zps6da966fa.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc00978_zpscc55baf0.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc00981_zps9b7564d6.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc00979_zpse0b16c27.jpg
Step 2: Disconnect and Remove all seats from the vehicle. Be careful as they are quite heavy. NOTE--The center console has carpeting on its sides. However i did not find it necessary as the area could be easily masked off.
Step 3: Remove both Kick Panels,Floor Heating Ducts and Floor Carpeting.
Step 4: WASH/Powerwash and SCCRRRUBBBBB carpet VIGOROUSLY!!!! I cannot emphasize with enough exclamation marks how important this step is. Dry thoroughly in raging sunshine and vacuum after. NOTE--- due to the Thick foam/sponge backing drying might take a complete day. However after that is complete your carpets should look almost if not better than this when clean.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01008_zpsccd01068.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01009_zpsb45af9c7.jpg
Step 4.5: While carpet is being dried, begin masking off door panels and the center console and the dashboard and begin sanding lightly by hand the areas to be sprayed.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01007_zps7650935e.jpg
Step 5: After sanding and wiping all surfaces to be sprayed in alcohol. Its SPRAY TIME!!!! I know, I couldn't wait either. NOTE-- This step is where one should exercise patience and for several reasons.
1) Over-spraying causes the paint to run.
2) The first two coats should be extremely light.
3) Saturating the carpet causes the fibres to be almost inseparable.
I begun with the Kick Panels first as they were the easiest (3 Coats).
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01004_zpseb5769f1.jpg
Continued unto the Rear Quarter Panels. (3 Coats)
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01000_zps4cf70492.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01003_zps3c813082.jpg
Moved to the Carpet. (9 Light Coats) Yes that is correct nine LIGHT COATS!!
Doing the carpets is easier than it looks especially following these simple steps. 1) Spray Lightly. 2) Allow 5-10 Mins drying time between each coat. 3)Brush Vigorously in all 4 directions immediately after applying each coat - This exposes unsprayed areas and stops the fibers from sticking together. NOTE AGAIN -- Brush vigorously after light spraying. Forgive my repetition, its really emphasis.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01010_zps1103d501.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01012_zps6381dfce.jpg
Step 6: Door Panels and the Center Console.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01015_zpsf42603cd.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01013_zps91a2ce13.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01022_zps77b83397.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01023_zps65b2694a.jpg
Step 7: Begin placing your seats and carpeting where they rightfully belong.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01026_zps1bbf6978.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01027_zps932f7761.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01025_zps9a9cfae0.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01029_zpsc7bbc45e.jpg
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-dsc01032_zps7d548f60.jpg
Step 8: GOOD LUCK!!! lol. I am very pleased with the results and have been receiving a tsunami of compliments and "do it for me's" Ultimately, the most important step is preparation. I am now in the process of acquiring a good quality fabric paint marker so i can paint the stitching in the seats red. Oh well thats another project by itself but ill definitely keep forum members posted. Thanks for taking the time out to read this post and if you ever decide to undertake and have questions i'll be honored to assisst in any way i can.
Till then my friends.
How I Refreshed My Benz Interior Using Dupli-Color Spray Paint.-complete.jpg
Reply 1
Jan 11, 2013 | 01:28 AM
congrats on the diy. glad you are happy with the result.. Was is tough taking the entire interior apart? I am not interested in painting my interior but do want to dynamat the entire car and this looks like a good start. Did you just follow directions found on here for removal of all the seats and door panels front and rear?
Reply 0
Jan 11, 2013 | 01:55 AM
Quote: congrats on the diy. glad you are happy with the result.. Was is tough taking the entire interior apart? I am not interested in painting my interior but do want to dynamat the entire car and this looks like a good start. Did you just follow directions found on here for removal of all the seats and door panels front and rear?
Hi my friend,
Yes i did for the front door panels but for removal of everything else it was pretty straight forward. Both front seats are held in by 4 torx head screws to the floor. (9 or 10mm i think). The rear base seat just lifts right up and is not held in by any screws. However the back is held in by 2 bolts (15mm i think) at the bottom. 1 screw holds in the kick panels each and the rear quarter panels are held in by push clips and are quite easy to pry off..be careful though as they are designed to break easily. The carpeting can then be removed with ease to dynomat. View the attached document for removing a door panel.
Reply 0
Jan 11, 2013 | 12:04 PM
Very Detailed work.... The only thing I would add is that I, and many others have found Dupli-color to not be the sturdiest of product, and tends to flake in high traffic areas such as door pulls and where you rest your arm on the door, basically, areas that flex. I would recommend that you use an adhesive promoter product as a base coat on vinyls, or use SEM dye instead of duplicolor paints, SEM seems to bond better, and hold longer. The other option is that pretty much any auto upholstery shop will sell you a bottle of actual profession grade product for about $18 bucks... Yes, it's more expensive, but like with any professional product, you use much less and get much more. Another Caveat for a project like this is generally you want to perform this in weather of about 72 degrees F or above. Other than that, enjoy the fruits of your labor.
Reply 0
Jan 11, 2013 | 05:22 PM
Quote: Very Detailed work.... The only thing I would add is that I, and many others have found Dupli-color to not be the sturdiest of product, and tends to flake in high traffic areas such as door pulls and where you rest your arm on the door, basically, areas that flex. I would recommend that you use an adhesive promoter product as a base coat on vinyls, or use SEM dye instead of duplicolor paints, SEM seems to bond better, and hold longer. The other option is that pretty much any auto upholstery shop will sell you a bottle of actual profession grade product for about $18 bucks... Yes, it's more expensive, but like with any professional product, you use much less and get much more. Another Caveat for a project like this is generally you want to perform this in weather of about 72 degrees F or above. Other than that, enjoy the fruits of your labor.
Thanks for the heads up Scott. I will definately keep that in mind for future detailing. Where i currently reside dupli-color and many other quality fabric and vinyl paints arent available, those products in particular have to be imported. Additionally, i will be monitoring it and providing forum updates where necessary and trust me the temperature here averages 30Celcius year round.
Reply 0
Jan 13, 2013 | 08:05 AM
I like it!
Reply 0
Jan 15, 2013 | 08:53 PM
This is amazing, now all you need to do is wrap the wood in carbon fiber
Reply 0
Jan 17, 2013 | 12:22 PM
Quote: I like it!
Thanks ThatsMyDawg...i really appreciate the compliment. i'll be working on painting the stitching of the seats next just to top it off. I have been doing some research about Elmers Paint marker and based on the feed back i am getting and the results i've seen (over the internet of course) i am willing to give it a try.lol
Reply 0
Explore
Jan 17, 2013 | 12:50 PM
i am not a fan of "spraying" specially interior but you actually did a good
job on this one
Reply 0
Jun 21, 2013 | 11:43 AM
haha you are such a great taper. and very patient.
cant say the same for myself
I rushed it a bit and now its taking me much longer than I thought it would.
but I am also swapping out the ugly Subaru fabric with some white leatherette that I got from my local fabric store and they are melted into the door panels, so yeah :/
if anyone is interested, check it out let me know what you think.
loving the red!!! superb!
http://s1304.photobucket.com/user/Mu...?sort=6&page=1
Reply 0
Jun 24, 2013 | 09:41 PM
I saw the headline and had to chime in. Hoping you were using a Dye type of paint.
Lacquer based dyes and for small jobs shoe leather dye.
Preparation predicts the life of the finish. I have some interior parts on an old cougar 20 years still holding.
Jamaica - cool, have a bud from Kingston Alcoa chemical industry, raced Lotus there.
Stay away from the ganga. Good Rum. LOL
Cheers, Gator
Reply 0
Jun 28, 2013 | 03:03 PM
very good.. Im looking to clean my side door panels..rest its good to go
Reply 0
Jun 28, 2013 | 10:22 PM
That came out absolutely Awesome. I am seriously jealous and impressed. How would that spray work on cloth seats?
Reply 0
Jun 29, 2013 | 12:25 PM
Tried black on cloth seats, already fading, haven't decided what I'm going to so yet but I would not reccomend it. At first it looked awesome, you know what you should try, try the simply spray and let us know how that works. I have a feeling it would be better. I like the concept of rubbing it in with your hands. Sounds legit,
Reply 0
Jun 29, 2013 | 12:54 PM
Quote: I saw the headline and had to chime in. Hoping you were using a Dye type of paint.
Cheers, Gator
Hi GatorMB,
Yup its die paint alright. The carpets soaked the paint up like butter on bread. Prep work is key for a long lasting finish. Stay away from ganja huh? hahahaha i have no comments on that one. Why drink and drive when i could smoke and fly. The rum is great also, sometimes even a bit too strong for me.
Reply 0
Jun 29, 2013 | 12:59 PM
Quote: Tried black on cloth seats, already fading, haven't decided what I'm going to so yet but I would not reccomend it. At first it looked awesome, you know what you should try, try the simply spray and let us know how that works. I have a feeling it would be better. I like the concept of rubbing it in with your hands. Sounds legit,
Im loving the transformation of your interior. It looks gorgeous. Srry to hear the paint on the fabric seats is fading. If i had farbic seats i'm not sure i would have attempted it, but have you looked into using SEM paint dyes rather than dupli-color?
Reply 0
Aug 15, 2014 | 04:48 PM
resurrection of your thread.
Hey guys wanted to say you inspired me to do the job myself. Your cashar looks good!!! I currently removing the dashboard off completely to prep for paint also running into a few things a long the way. my question was how is the dupli color holding up on leather interior that is what are dash door panelsare made of ,right?
Reply 0
Aug 26, 2014 | 02:48 PM
Ruined a decent looking car... SMH
Reply 0
Aug 26, 2014 | 04:36 PM
Reply 0
Aug 26, 2014 | 06:45 PM
Quote: Ruined a decent looking car... SMH
It all depends on what part of the earth you are standing. I think it is a bikini melter in Jamaica.
LA, NY, Miami maybe a target for DEA none the less you will be judged for the star wherever you live. Best to just enjoy and forget the haters.
Gator
Reply 0
Jan 2, 2025 | 11:17 AM
Attachment 409795
Attachment 409796
Attachment 409797
Attachment 409798
Attachment 409799
Attachment 409800
Attachment 409801
Attachment 409802
Attachment 409803
Attachment 409804
Attachment 409805
Attachment 409806
Attachment 409807
Attachment 409808
Attachment 409809
Attachment 409810
Attachment 409811
Attachment 409812
Attachment 409813
Attachment 409814
Attachment 409815
looks good man! I'm currently waiting for my new redwine seat covers, custom made floor mats center console cover etc because mine is the same boring color interior as yours was. When the weather gets nice again I'll be doing the doors as well black and red. It's gonna pop so much more I think then our gray and beige
Reply 0
Jan 10, 2025 | 05:55 PM
I have tried the dulpi-color restore as well, and was not completely satisfied with the results. There are dyes for leather and vinyl, that work much better and come in the different sheens. They are extremely easy to apply, be it by sponge, brush, roller, or spray gun. LeatherWorldTech.com has everything needed for leather repair and restoration. I have also change the color of my carpet using RIT dye, which is not easy, since you have to maintain temp of dye solution.
Reply 0
Subscribe
Currently Active Users (1)
