W208 Cabriolet CLK M273 engine swap
I want to retrofit the paddle shifting steering column as well.
I have been thinking -
AMG suspension
AMG differential / axles / drive shaft
AMG brakes
just a little worried about chassis shimmy - being a cabriolet and all..
your comments and suggestions will be greatly appreciated..
In my mind it would be cheaper to just pick up an old 5.5L car... Maybe a CLK55, E55, or a CLS55
Regarding suspension, maybe you should look into lowering springs and some sport shocks to reduce wheel gap for that nice flush wheel to fender ratio. I think CLK's sit too high on stock or AMG suspension, but that's just my opinion
Successfully installing an M273 would put you in the rare air of CLK Royalty. You’d be mentioned with the likes of J Williams, Ash, Betrezra, Kevwood, and dare I say it – the fastest 208 known to man – BlackBenzz.
Best wishes with the upgrade.
let me start by saying anything is possible.
if your car is a 2001 or 2002 you have ME 2.8 which means you can convert the w208 55 parts as a plug and play if not then you have to do the full conversion of all modules, computers, body harness, Security system EIS and a tone more basically everything that I did. after that you have to go one of the following routes:
1. upgrade everything on your car from fuel pump to axels, drive shaft, diff, trans etc.. to the w208 55 because they are the same as the 600s which are the v12s. the w208 55 was very much solid and over built when it comes to drivetrain. then you will have to adapt the new engine to the w208 55 transmission and adapt the wiring harness to the w208 55 ME(ecu) and make custom hoses for the radiator and other parts such as AC, oil cooling etc... after you have done all that you will have to get a custom tune to allow the w208 55 ME(ecu) to run the new engine properly. this is not a simple task nore is it something companies like wistech and powerchip can do, this has to be done by an actual programmer/tunner with very very very extensive knowledge of benz and on a dyno which could run into months of tunning and a very hefty budget.
2. have a custom body harness made and use everything off of the CL such as the gauge cluster, all modules, window motors, cluster, climat control, basically everything in the car.
option one would be your best bet but even at that you still have to see if you can make or have a custom engine harness made to allow communication between the w208 55 ME(ecu) and the 273 engine or not. this is not as simple as just running wires, everything inside these carsfrom windows to lights to outside the car in the engine and trans is controlled by the ME(ecu) and canbus system. if you can figure all that stuff then you might have a shot at this but you are looking at a very hefty budget and I can tell you at the end is not gonna be a reliable carbecause there is a lot of custom and cutting and chopping work involved. and possibly many custom parts such as crank sensors, heat sensors, custom hoses etc...
my project took about a year of research and about 3 months to be competed. I am in no way a mechanic or have much knowledge of cars. I work in the financial industry and did this in my spare time at a friends shop. but for your project you have to set aside many many many months to get this to work because like I mentioned it will be fully custom with absolutely no point of refrence. but before you start do your research and talk to a tunner/programmer with benz knowledge. ive seen way to many people start a conversion and then you never hear from them again and months later you hear their car was parted out or sold t a junk yard. prime example is a few months ago that a member swapped the 32k motor in his clk and already had everything installed and just needed the wiring figured out, no one ever heard from that car or member again. the mechanical part is the easy part can be done in a few days, the wiring is the monster project! and one advice I can give you, don't for a second think that"its just wiring, they make a big deal about it" it is a big deal and the biggest deal and the only reason why none of these transplants ever get done. these cars are completely electrical driven and canbus controlled.
if you have a the time, money and patience do it, I would love to see this done.
P.S. if you want a fully reliable daily driver I don't recommend this project. I went my route because I wanted a fully reliable daily driver and I achieved just that.
Thanks for the comments on the final vehicle being in the upper echelon of world wide CLK's. besides the engine swap out here are the other planned modifications:
1) PriorDesigns Wide Body Kit with rear spoiler
2) custom built rear seat area high power stereo system
3) rear black led tail lights
4) front black ccfl projector headlights
5) custom extension of existing cabriolet storage top to extend with same lines to front seats (similar to the old ford thunderbirds)
does anyone have a link to a repair manual out there - as aforementioned - I need to start straightening out the electrical system to at least get the trunk switch to work (no key as well)..
Kindest Regards
Bruce - Trinidad & Tobago...
