OBDI ECU engine Bay / Alternative opening methods
Summer sneaking in aaah soon all soon is time again..
Anyway quick question on ideas to open the OBDI Diagnostic engine bay?
I don't have the tool no idea what it called thus why doooh!!!
Anybody can help?
Or alternative method to get to the diagnostic port without removing the cover screws ?
any help ideas, is appreciate.
Europe..
is like this one. or data cable connecter, that round thing to open into the box I have no idea what it is called :-) I need the tool, or alternative if there is one?
I just take the whole cover of, but is a hazle mate.
Mine is left side tough...
Europe..
the MB with OBDI is 38 pins, not 32. something tells me you are old bimmer driver, they got 32 pins J.
And the OBD II has 16 pins located under dash drivers side I know that, but that's only the US models, since they made it by law to be like that.
OBDII is preferred actually but it doesn't change anything.
Got the WIS/DAS Star yes..
and to answer my question, twist and turn and voila open.
No problems with car/engine
adjusting and setting the engine up for my wishes!
Guys it was a simple question really and I appreciate your enthusiasm
but none of you answer my question
Anyway thank you both, I found out its done, and more adjustments coming. Like I said had it open many times, timing fuel and other variable adjustments done. ECU upgraded / TCM (Transmission control module) Kleemann Sweden.
As you can see, my 3 year ownership, far from standard ;-)
Please be so kind as to let us know how you improved the ECU settings; I was under the impression that one had to re chip the ECU to change the mapping profiles.
Yes was the small cover, oh with a allen key to, but of course haha.
open it with a 12 mm socket, guess easier having the allen key in the trunk.
ECU was improved by Kleeman Sweden (1566.81us dollars)
After that for the test I had a chip tuning guy over just to see if there was anymore to gain, he came he plugged in and I still hate myselfe for not paying attention to Software/Wiring tools. took aprox 56 min total for him to download the file and he was still able to gain aprox 13HP.
not much for a 626.72us dollars thus dropped it.
Kleeman installed headers, the final and last set they had available i stock, thats Europe not sure if is possible.
there is a lot of talk about this issue, and I can say I had contact with Kleemann Denmark first who told me to forget it, their attitude was enough for me to move on to Kleemann Sweden, they don't judge you old/new car, same treatment nor AMG up here they do it really well.
Anyway they took out the ECU had it open op and well is how is done, should be possible to download and remap your ECU yourself!
Download org file save it and stored it good.
And then there is the software/hardware, for a OBDI car like mine is a pain in the butt. I had success with only 1 software the multiplexer
CarSoft 7.4 worked, on some modules not all, you can get it to work but is a hazzle, you can access the various modules by connection through the pins as on the added picture.
Live feed works tough and very good to diagnose fuel and other driving variables.
It can be done, but right now there is so much fake software/hardware out there it is total jungle!
