help roof won't work on my 2000 clk430
Old Mar 28, 2014 | 04:00 PM
Davpang's Avatar
Clk430 amg
I closed the roof when I got to the mall and when I came back and went to open it again all I get is the windows come down and the light keeps flashing on the roof button
Old Mar 28, 2014 | 11:31 PM
Hitman0187's Avatar
CLK430
sounds like you are either low on fluid or the wires in the passenger side trunk area are cut
Old Mar 29, 2014 | 12:01 PM
Davpang's Avatar
Clk430 amg
How can u check the fluid?
Old Mar 29, 2014 | 02:58 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Open the trunk and you'll find an opening flap in the carpet that you can look through with a flashlight to check the fluid level.
The opening is to the left of and slightly lower than a similar flap, used to release the hydraulic pump relief screw, that is used to raise the top manually (see owners manual).
Sounds like you haven't used the forum's search function.
The power roof is very complex and it's operation involves an electronic controller, hydraulic pump/motor/relay, 7 hydraulic cylinders, 15 or more limit/position switches, tension cables, windows and roll bar operating properly.
The W208 convertibles are now 12 - 16 years old so, it's not a question of 'if', but 'when', something in the power roof system will require repair.
As a result, if you have good trouble-shooting/repair skills. there is a ton existing DIY information in the forum (e.g. search is your friend).
I know it's a pain, with many dead ends due, due to numerous new members asking for help on a topic that has been already, throughly covered.
Alternatively, the STAR diagnostic software, available at MB dealers and some independent mechanics, can be used to further diagnose and/or repair the problem.
Old Mar 29, 2014 | 05:37 PM
Davpang's Avatar
Clk430 amg
I checked couldn't really see anything but doing some research I have found out my headrest don't go up or down when I push the button
Old Mar 30, 2014 | 04:45 PM
Top Hydraulics's Avatar
SPONSOR
03 SL Kleemann, 97 SL320 pano top, 95 Lorinser E320 Cabrio, Ferrari 360, Tesla X
Davpang,
welcome to the forum! Where are you located?
It sounds like you will have to roll up your sleeves a little for troubleshooting, or pay a dealer for reading codes via StarDiagnostics. If you are willing to roll up your sleeves, after doing some reading, then I would recommend browsing through this most comprehensive thread on the subject: https://mbworld.org/forums/clk-class...-failures.html
Checking the fluid level in the pump is essential (as suggested by serndipity), as are checking out the 40A fuse in the trunk and the relay next to the pump. Instructions for access to the pump and the relay are part of the following DIY: http://www.tophydraulicsinc.com/W208...eplacement.pdf
Klaus
Old Mar 30, 2014 | 07:52 PM
Hitman0187's Avatar
CLK430
you may also want to make sure the cover in the truck is closed tightly as well.
Old Mar 31, 2014 | 07:19 PM
Davpang's Avatar
Clk430 amg
Thanks for all your help I found the problem it was the relay it was a pain to get to but solved the problem
