Loud howling near fuel pump
Old Apr 26, 2015 | 07:13 PM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
I'm getting a very very loud howling from the fuel pump area. I have already changed the fuel pump and filter. I can make the howl disappear by squeezing a certain spot on the fuel hose which comes out of the fuel filter. If I were restricting the fuel flow somehow and that is making the noise go away, why not at other spots that I'm squeezing. I'm sure there is a logical explaination for this, just don't know what it is.
I made a video of it.
Old Apr 26, 2015 | 07:58 PM
MagmaRed55's Avatar
Magma Red W208 55 AMG, W203 C230 Kompressor Sedan 6speed M/T, W220 S500
This is interesting. The only thing I can think of is, maybe that section of the hose has collapsed on itself and by you squeezing that section, you are opening it back up. Just a thought. Hope you find a solution to this.
Old Apr 26, 2015 | 10:16 PM
marko69's Avatar
Good point, I didn't think I might be actually opening the hose. I Shudda tried rotating the squeeze at that spot. The car has been running fine, even at 140mph a few weeks ago. I'd think there might be some hesitation or stumbling but maybe it is open just enough not to cause a problem. I'll replace the hose in any case.
Old Apr 26, 2015 | 10:22 PM
MagmaRed55's Avatar
Even though it's running fine, I can only imagine that if it is in fact restricting the flow it would shorten the life of the pump. 140 is a good speed to find flaws though. Hahaha good luck man. I'm curious to know if a new hose will fix your issue.
Old May 10, 2015 | 11:26 AM
marko69's Avatar
Replaced that hose, no change. Put in a new Mercedes fuel filter and the howl is gone. I guess the new Mann filter I put in a few months ago was bad. I would never think a fuel filter would cause this, but I understand there is also a pressure regulator in there as well.
Old May 10, 2015 | 04:37 PM
MagmaRed55's Avatar
Glad you got it squared away. I'm sure someone will run into this problem and can use this to help solve it. Good job, sir.
Old Jun 11, 2015 | 12:09 AM
pigman's Avatar
2001 CLK 55 AMG
Originally Posted by marko69
I'm getting a very very loud howling from the fuel pump area. . .
Thanks for posting this. It started happening to mine a few weeks ago and, from inside the car, it sort of sounded like a stuck horn. I thought it might be the fuel pump so I'm happy to hear it might just be a fuel filter.
Old Oct 24, 2023 | 07:00 AM
mikola's Avatar
W202 C240
I had exactly the same problem. What was weird is it started making that noise a day after changing the fuel filter. It was KolbenSchmidt. I changed it to Mahle, and the noise disappeared. It seems the filter was either defective or fake.
