Anyone with C32 Brakes.
Old Feb 27, 2004 | 11:26 AM
  #76
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
Originally posted by theine
I had to put 3mm spacers, impossible to drive it without them, I am waiting for the ST4's to arrive, then I won't need spacers.
http://www.benzworld.org/gallery/goto.asp?id=27941
Close up photos of my C32 AMG Brakes.
http://www.benzworld.org/gallery/goto.asp?id=27937
http://www.benzworld.org/gallery/goto.asp?id=27938
those look nice... why don't you step up to 19s? the ride quality isn't that much different...
Old Feb 27, 2004 | 11:28 AM
  #77
mmgrad's Avatar
Originally posted by CiLKY
I'm putting some of these on my car as soon as my stainless steel lines and porterfield rs4 pads show up. I figure with that setup it would brake just as well as the brembo kits. I'm putting the pads and lines in both the front and the rear. Should be sweet.....then I'm gonna do a track day woohoo
OH yeah these calipers/rotors are heavy as $%&!
26.10 lbs for each rotor!! But they sure are big!
Seriously... they are huge, but damn... its about 80lbs for the total package... insane!
i wonder why MB are using such heavy setups on their AMG cars... a floating caliper system would obviously shave off unnecessary weight...
Old Feb 27, 2004 | 12:12 PM
  #78
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
As everyone in this forum has noticed after all the mods I've done, I still have my original 17" wheels, simply because the ride is very important for me, the 18's will be a little more harsh and the 19's more than the 18's.
Old Feb 27, 2004 | 12:24 PM
  #79
CiLKY's Avatar
13 S550 4Matic
Ohhh come on through some 19's on there!!! It is a little rougher but you get used to it so quickly (1-2 weeks).
I need the brakes just to fill up the wheels. Look at my little puny stockers in my sig pic hahaha
Old Feb 27, 2004 | 01:23 PM
  #80
mmgrad's Avatar
theine... don't sweat it... you don't even drive your car that much, so why would it matter SOOOO MUCH.... you've put on what, 10,000 miles in 3-4 yrs?
go with the 19s...
Old Feb 27, 2004 | 01:24 PM
  #81
theine's Avatar
You sure need bigger rotors, on the other hand my wheels look tiny compared to the huge rotors. :p
Old Feb 27, 2004 | 01:37 PM
  #82
theine's Avatar
go with the 19s...
On 2002 I put on 3,000 miles, on 2003 a little more, 4,650, this year I wen't wild, already 1,500, got to slow down....
The wheels won't arrive until after 3/15, so I have time to decide, but so far I am leaning towards 18's, the CLK is a small car, and I think they look better, but that's my personal taste.
Old Feb 27, 2004 | 01:42 PM
  #83
mmgrad's Avatar
no no... the CLK is not that small a car...
18s look good... 19s look GREAT!!!
20s are a stretch, and soemwhat overkill...
Old Feb 27, 2004 | 01:47 PM
  #84
CiLKY's Avatar
13 S550 4Matic
Listen to Danny and go with 19's!!! you wish you had if you go with 18's.
Just curious are the roads that bad that you need 17's? 19's are not that much different.....I mean you already have suspension so the wheels won't make 1/3 diff that did.
I think my wheels are the perfect ones to show off those new calipers/rotors! I can't wait to put them on!!!
Old Feb 27, 2004 | 01:58 PM
  #85
theine's Avatar
Which rotors are you putting on the rear? I have AMG's on the front and Brembo's on the rear, so all four corners have drilled rotors.
Old Feb 27, 2004 | 02:11 PM
  #86
mmgrad's Avatar
homeboy, you better update you sig...... those red brakes are screamin rice...
Old Feb 27, 2004 | 03:04 PM
  #87
CiLKY's Avatar
13 S550 4Matic
As soon as I get mine put on mid next week I'll get a new sig pic....also a smaller picture hahaha
I'm gonna keep my stock rotors for the rear at the moment. It is easy enough to swap out some x-drilled later.
Old Mar 2, 2004 | 08:01 AM
  #88
CiLKY's Avatar
13 S550 4Matic
Here is a preliminary Pic........ putting the lines on today and my pads will be in tomorrow from Porterfield.
L8tr
Jeremy
PS why have I not read anywhere that the rotor set screw (the one that just holds it in place till you bolt your wheels on) does not fit........it isn't an issue because once your wheels are on it becomes useless, but I guess no one has done this mod themself.
Old Mar 2, 2004 | 09:58 AM
  #89
mmgrad's Avatar
L8tr
Jeremy
I've seen that pic before... I think everyone has done the RED X mod.... hehehe...
your host won't let you link pictures from another site... just use benzworld or something
Old Mar 2, 2004 | 10:11 AM
  #90
CiLKY's Avatar
13 S550 4Matic
Link Fixed........it was showing up on my end but I threw it up on benzworld just to make sure
Old Mar 2, 2004 | 11:45 AM
  #91
mmgrad's Avatar
well... i had already saw that picture... you just have to view the source of the pic, then open it in its own window...
