Cluster cluster #%*~
I changed it with the car off, and it works great. I replaced mine due to a portion of the dash no longer lighting up. To repair just about anything in your cluster just buy a working cluster that has the same features, same car, same year, and same tach as yours, then change your rear board to it, it's only about 5 small connectors. You only need to keep the rear board with the car.
The procedure is very simple, Move the steering wheel all the way down and towards you. You will want a plastic tool to pry the bezel around the cluster towards you, grab it with your fingers and pull or you will make marks on it if you use a tool the whole time. Remove the dimmer selection knob after the bezel is off by pulling it towards you. Then you need a torx 20 driver to unscrew the 4 screws. You should be able to tip the cluster forward and reach the connector now, the main connector has a clip that locks an arm so push the clip in and rotate the arm, that unplugs the connector, see photo for how the connector works.
There are some very easy to release plastic clips that hold the cluster together, no screws, so pop that apart. Once you're inside, there are 4 more plastic clips holding the entire assembly into the back half of the case. Pop the assembly out of the case using a small screwdriver on the clips. Now you have the inner workings out, set them face down on your work area, using a cloth or something to keep the face safe. Now look at the photos on where to gently pry to release the connectors, there are three of the first kind and two of the second. Now the entire rear board that stays with your car comes off with 4 more easy plastic clips. Now put your cars rear board into your new cluster and install everything in reverse.
I've attached a photo of the rear board removed, illustrating the two types of connectors you will have to unplug and reconnect, if you are not familiar with the connectors you should look close at the photo on how to release them.
If this looks too difficult send it out.
Cheers.
Cheers.
That cluster was one given to me everything seems to function on it on the bench. It is an interesting project to play around with coding, etc. I would not attempt to mount it in the ML - I did convert the ML320's cluster to display AMG information, such as a lap timer (in a Diesel SUV! ), current gear, upshift recommendation, oil temperature, and battery voltage.
