0-60 ? and 1/4 mile times ? CLK 430
Old Mar 31, 2004 | 11:13 PM
Big Terry's Avatar
2001 CLK 430 Silver
just wondering
Old Mar 31, 2004 | 11:40 PM
XxGoppyxX's Avatar
2005 Clk 500 Coupe
my fgreind had this thing that plugs into the cigarette lighter and attaches to the windsheild. put the weight of ur car in and it can tell u 0-60 60-0 whatever.
the best i got was 5.8 with the traction controll off
Old Mar 31, 2004 | 11:48 PM
Big Terry's Avatar
2001 CLK 430 Silver
Wow, sounds pretty good to me, are you stock ?
Old Mar 31, 2004 | 11:52 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
I also have one of these timers. My best was done with a full tank of gas and 1 passanger, with a time of 6.3s. Combined wieght of me and passanger is 420lbs, and I had esp turned on, and the road was not that dry :/ I believe with a dry road and only me in the car, I could get under 6s without esp on. My car is stock with K&N filters.
Old Apr 1, 2004 | 12:00 AM
Big Terry's Avatar
2001 CLK 430 Silver
Question
Were do you get those timers
XxGoppyxX's Avatar
2005 Clk 500 Coupe
im completely stock.. im still skeptical about the 5.8...
Old Apr 1, 2004 | 12:13 AM
CHB's Avatar
CHB
There are many different companies offering different products. I got mine from escort, I just phoned them and in 3 days I had it delivered. I'm very happy with it
http://www.escortstore.com/gtimer.htm
Old Apr 1, 2004 | 12:25 AM
CLK430ROB's Avatar
If your talking about the GTech Pro... they are pretty damn accurate as long as you have your information correct. Actual weight of your car with you in it... etc...etc...
Rob
sLickfITY's Avatar
ive heard of these things not being too acurate...
Old Apr 1, 2004 | 12:30 AM
CHB's Avatar
CHB
With 1 passanger and esp on, 6.3s seems to me pretty close. When I went for a 1/4 dash, the speed the timer gave me was 1 mph off my accualt speed on the speedo.
Old Apr 4, 2004 | 04:06 PM
count_schemula's Avatar
1999 M Coupe
Found this in the MB World world specs section:
Coupe: 6.1 sec
Cabriolet: 6.9 sec
Found this on another MB board...
Estimated times are:
1/4 Mile: 14.5 - 14.7 sec.
0-60: 5.5 - 5.9 sec.
Dyno Output (from personal experience) 245 hp and 255 Tq.
We'll see. A friend of mine just got a new 99, so, maybe I can talk him into going to the dragstrip in Commerce for some runs.
Old Apr 5, 2004 | 10:28 AM
Chappy's Avatar
AMG
What has been you best run up there? I recall the M Coupe (240hp version) was good for 0-60 times in the area of 5.2 seconds. I always liked the M Coupe
Old Apr 5, 2004 | 12:58 PM
1999 M Coupe
My best run was low to mid 14 with a ~96mph trap. It was my first time ever dragging and I only dropped from a little over 3000rpm to save some clutch.
The Commerce track in particular is pretty slow. I think it's over 1000 feet. I've heard you can adjust your time by about .2 compared to a lower lever track.
At Silver Dollar or similar I'd fully expect to do a 14 @ 100mph.
There are 2 types of M Coupes as well. Mine is the S52 motor 240hp/236 ft/lb of torque. Then there is a 315hp/256 ft/lb of torque S54 motor.
The S54 breathes much better up top and revs higher than my engine does.
We'll, see. I'm going to pick-up my friend's CLK430 tommorrow.
Old Apr 5, 2004 | 06:15 PM
blackbenzz's Avatar
haters crazy
My brother has a m coupe (stick) and one of my cars is a clk430 and he kicks my *** 0-60, but its all me after that. Just to let you guys know.
Old Apr 5, 2004 | 06:21 PM
1999 M Coupe
Cool.
At 3300-3400 pounds, the CLK430 is lighter than I thought by about ~250 pounds. Alloy blocks!
The M engines have iron blocks.
I'm excited to see what's it's like.
Old Apr 5, 2004 | 07:38 PM
unsung's Avatar
06 M3
What is the overall CLK 430 Top Speed? Isn't it limited to 155 mph?
Old Apr 5, 2004 | 08:29 PM
Chappy's Avatar
AMG
130 mph.
Old Apr 5, 2004 | 09:24 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Be sure to shut off the ESP and Reset your ECU for max power!
Have fun!
Old Apr 5, 2004 | 09:43 PM
clkal's Avatar
01' CLK55
130 mph.
i believe it is 135 MPH if i'm not mistaken
Old Apr 6, 2004 | 12:06 PM
jddumas's Avatar
2006 E55 & 2009 Audi S5
That's a question I have wanted answered. I have a completely stock CLK 430 and I was able to get mine up to around 140 and slowed back down due to high winds on a bridge I was on. I have been reading on posts that it would cut off at 130, but mine didn't for some reason. It still had plenty of pedal left too. Any suggestions on why it didn't cut off?
Old Apr 6, 2004 | 12:45 PM
1999 M Coupe
Speedometer error can reach close to 10% at those speeds.
Plus, on BMWs anyhow, the cut-off is 137mph and for some reason I think it's close to 150 for faster cars like the M5. I need to check the latter out though.
Old Apr 6, 2004 | 08:07 PM
seealkay's Avatar
they should take off the stupid limiters on smaller cars like the C, clk, slk, Sl. the 55s especialy sl should put on some good paper number for top speed without it.(lot more buyers)
how do u reset the ecu?
Old Apr 6, 2004 | 08:30 PM
Chappy's Avatar
AMG
Call Evosport. $990 bucks.
Look here....
http://www.evosport.com/product/perf....html#software
Old Sep 2, 2017 | 03:32 AM
Aaron Wayt's Avatar
1999 MERCEDES BENZ CLK430 AMG 2DR 4.3 L V8 RWD (Soon2bAWD) 400 HP 5SPD AUTO 155T./0-60 TRAC. On 3.2s
Tsk Tsk Well that certainly all depends
Depends on if you're speaking of the CLK430 or CLK430 AMG both of which are different. The base 4.3 has 275 HP with 4speed tranny, and is governed to a top speed of 135, 0-60 in about 5.6 secs. Than you have my favorite little 1999-2003 Baby Rabbit. The CLK430 AMG with 400 HP, also 5speed tranny, with a Governed Top Speed of 155, 0-60 in 3.2 secs normally with FULL FUNTION, but mines pushing 3.4 secs right now due to it being in a slight state of Limp Mode. Just gotta change out the 2 nobworking O2 Sensors in the A.M. (Changing all 4 instead though) and than I'll have all 400 Horsies again. YAY!! BTW it's just a governor, you can bypass it so the speed it can go really has no limit but in doing so you risk chipping gear plates, newfound slipping, no shift, etc etc. Basically destroying the Hard to rebuild Auto high intellect the Beautifully designed, engineered, and Built. No longer made anymore, ALMOST INDESTRUCTIBLE, 5speed 275-400 hp Transmission and The Bullet Proof, barely any left, high powered, high performance, High intelligence Engine. Unless you put in Like top of the line High Performance aftermarket parts that can handle the heat, torque, and tension. It just wont allow itself to break anything mechanical. It's all protected. As long as all your senors are good when you start the car up and drive it, if anything isn't right, or a sensor starts acting up the car will stop itself before damage is caused to mechanical parts. Just oil, tires, and brakes ive had to change. Simple sensors are the only parts I've had to replace beside what was previously stated due to maintenance of course every once in a while. All in all Favorite car I've owned. Haven't even owned it all that long but long enough to decide IM INLOVE.
Old Sep 2, 2017 | 03:34 AM
Aaron Wayt's Avatar
Depends on if it's the Base Model 135 or AMG package 155 Governed top speeds. Theres much much more pass the Governor.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
