2002 CLK 55 Electrical Issues
Old Feb 28, 2017 | 09:00 AM
Veritas17's Avatar
2002 CLK 55 Cabriolet, 2008 G37 Sport, 1982 Corvette
I have 105,000 miles on my CLK and for the past year of so the dashboard info area has been flickering, the other day while it was flickering the radio was cutting in and out and for about 10 minutes or so I could not open my windows, seats or side view mirrors. Not sure if this is all related to a a serious electrical issue or if as I have been reading the Pixels on the dash will eventually burn out, but the windows, seats and side view mirrors intermittent stop work is concerning. Any thoughts out there?
Old Feb 28, 2017 | 01:33 PM
PJmak's Avatar
Check if you have a loose ground.
I also heard a combination relay can cause this as well as a faulty blinker switch behind the steering wheel.
Does anything change when you flash your high beams and blinkers a few times???
Old Feb 28, 2017 | 02:23 PM
Veritas17's Avatar
I have not tried to flash my high beams and blinkers - I'll try it tonight. Where is the combination relay located?
Old Feb 28, 2017 | 02:24 PM
Veritas17's Avatar
Not looking forward to pulling the cluster... but will do if necessary.
Old Mar 1, 2017 | 10:14 AM
Highland doc's Avatar
2001 CLK 430 cab
The cluster just pulls straight out
Old Mar 1, 2017 | 12:05 PM
PJmak's Avatar
Its somewhere underneath the fuse box.
Have you done any work on the engine. Check your ground wire that goes from the power steering pump to the frame?
Old Mar 1, 2017 | 04:37 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Have you checked voltage at the battery?
