Need help fast!!!!! trunk won't open clk 320
Old Aug 2, 2017 | 07:21 AM
Angel.r's Avatar
Mercedes 2000 clk320
so this week I have time on my hands to work on my car. My convertible top wasn't working and my headrest was raised all the way up stuck had no fluid so I turn off the pressure off by sticking in a flat head and turning it. Then I removed everything from my truck to get to the motor pump. Found what's was leaking rear lock bow cylinders. I took off whole lock and I started taking the cylinder apart from the lock to sent it over to Top hydraulics to get it fix.Now I have no rear bow lock to keep the lock on place so it's kind of open,no fluid in the tank because I took out the old fluid inside, and my trunk doesn't want to open because it say the my soft top is open so the convertible switch has solid red light. I try to open the trunk with key,(spray with wd40) played with the lock for 10min moving it left, Remote holding the trunk open button and nothing
is there any way to open it now I'm stuck
Old Aug 2, 2017 | 12:01 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W208 forum...
Old Aug 2, 2017 | 03:38 PM
Angel.r's Avatar
Originally Posted by Plutoe
Go to any locksmith. They will drill out the lock!
I tried but nothing sound like my suituation please any. One else
Old Aug 2, 2017 | 03:39 PM
Angel.r's Avatar
no im okay read that's not a smart chose
Old Aug 2, 2017 | 04:24 PM
Angel.r's Avatar
thank you guys for replying got it to open
Old Aug 2, 2017 | 04:28 PM
hyperion667's Avatar
2012 CLS63
hot damn that's a dirty console
Old Aug 4, 2017 | 11:07 PM
Serndipity's Avatar
2001 CLK320 Cabrio
That's a huge NO-NO....that will not only not open the trunk, but will end in needless $$$$ to replace.
I would also suggest not spraying the key hole with WD40, as it leaves behind a sticky residue, which will fowl up the ability to turn the mechanical key, in the future. Instead, if the key doesn't turn, use a product containing graphite that does not leave behind a residue.
The trunk lock/unlock system normally is controlled electrically (e.g. via fob or console switch), which then pneumatically, releases the catch from the switch plate.
When using the mechanical key, make sure you follow the procedure described in the owner's manual.
Specifically, the lock will not release, by just turning the key (e.g. as many locks do).
The correct procedure, is to turn the key about 45 degrees, counter-clock wise and then push in, which should, over-ride the normal pneumatic operation and mechanically release the catch from the switch plate.
Old Aug 4, 2017 | 11:28 PM
MacVidMB-V8's Avatar
W209, W124
No wonder the switches are troubled, they're awash in filth.
Old Jun 5, 2022 | 01:07 PM
deebenz 226's Avatar
2000 clk 320
how did you get open
Old Jun 5, 2022 | 03:02 PM
2012 CLS63
Necro bump haha
