CLK430 Mass air flow sensor online
Old Dec 18, 2017 | 07:31 PM
markayash's Avatar
clk430
Smile CLK430 Mass air flow sensor online
I bought a "genuine" one on amazon but didn't work..Low voltage so probably a fake..Where is a good place on line to buy the Bosch
and know your getting the real deal?
Old Dec 19, 2017 | 09:00 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
https://www.fcpeuro.com/products/mer...sch-0280217810
Old Dec 19, 2017 | 09:16 AM
markayash's Avatar
clk430
I did clean the crap out of my old one before putting it back on and it seems to run better..Last time I sprayed it but may not enough?
Is there a "trick" to cleaning them?
For grins I ordered a MAF off amazon for $25, they said free returns and it's easy to swap so why not If it doens't work I will get the one above, good price
Old Dec 20, 2017 | 10:27 AM
insame1's Avatar
fcp also does lifetime replacements.
Old Dec 21, 2017 | 07:18 PM
markayash's Avatar
clk430
Actually this one works on my car..They are upfront it's not a bosch
Amazon Amazon
Old Dec 22, 2017 | 11:30 AM
insame1's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
No one said they dont work but they are very hit and miss and who knows how long it will last. I'm not saying there has to be but I am betting there is a difference in the build quality.
Old Jan 3, 2018 | 09:07 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
When it comes to any electronics on any car my rule is always by new genuine parts and if you cannot afford new genuine then by second hand but genuine. I have read so many people with reports of what they thought were genuine MAF's but only to find they are not. I have bought OEM MAF's and they both failed after weeks, which was the same for the infamous brake switch. Electronics are far more delicate and precise than mechnical which is why you can get away with a cheaper brand arm or exhaust for example.
For me the question is why is your MAF dirty and what kind of contmination? If it is oily then you need to get to the root of the issue as the air it is monitoring should be dry and clean. Yes you can clean the MAF periodicaly, however this should be done with car and will not like getting constantly cleaned.
Have a look on ebay for genuine Bosch MAF's that are for your chassis number they are pretty cheap now.
Old Jan 3, 2018 | 10:33 AM
markayash's Avatar
clk430
I agree
I mainly wanted to see if it would clear my p2098 code and it didn't..Mine was clean..
Still at a loss but have learned if I drive it semi easy and don't let it stay at a constant RPM for long it won't trigger the Check engine light so I got it to pass and got my tag
Now I have more time to fiq this weirdness out..Wondering about fuel pump now since no other codes.
Old Jan 4, 2018 | 09:38 AM
insame1's Avatar
I still think this is your answer. https://www.fcpeuro.com/products/mer...sch-0280217810
Old Jan 4, 2018 | 09:43 AM
markayash's Avatar
clk430
MAF
Seems weird the old and new MAF still put out p2098 and no other codes but may be correct..Wondering if a Mechanic has a better reader and may see stuff my $35 scanner doesn't or better yet know what the info means
Old Jan 5, 2018 | 06:23 AM
A1EK's Avatar
If both old and new MAF put out the same code then would this not indicate that it can't be the MAF that is at fault and must be something else?
Looking in the code I have read that its either the mass air flow sensor connector becomes contaminated with engine oil, the sensor hot wire becomes fouled with oil or other debris, or the air inlet pipe is cracked or broken allowing unmetered air to enter the engine. Aftermarket mass air flow sensors have also proven to be problematic on this type of vehicle. Faulty oxygen sensors are also fairly common in European models, due to oil fouling in the exhaust system. Other possible causes include an excessively rich fuel condition caused by a faulty fuel pressure regulator, faulty manifold air pressure sensor, or a faulty PCM. This code may also be caused by a lean fuel condition caused from a faulty fuel pump, bad fuel pressure regulator, clogged fuel filter, or engine vacuum leak. Keep in mind that PCM failure is rare. Turbocharged engines present their own symptoms, including fuel contaminated engine oil leaks that are drawn into the induction system. If camshaft or crankshaft sensor codes, ignition misfire codes, or low fuel pressure codes are also present, diagnose and repair them before attempting to diagnose this code. Catalytic converter failure may also contribute to this code being stored.
Old Jan 7, 2018 | 05:03 PM
markayash's Avatar
clk430
Smile Ordering the Bosch
Originally Posted by insame1
Its actually onsale
