208 CLK-Class tech bulletins
-CD Changer intermittently returns to Track 1 when starting, cars with COMAND model year 2000.
-COMAND does not respond to voice controls, model year 2001.
-Clicking noise from charcoal canister shut-off valve.
-Engine runs rough after coming to a stop or hesitates accelerating. Replace ME control unit. Does not apply to AMG models.
-Estimated time of arrival calculation is 12 hours longer than actual ETA.
-Front door windows reopen after closing with express-up feature.
-Hard starting after fuel filter replacement.
-Implausible oil level display in instrument cluster, leaky oil level sensor/oil pan.
-Instrument cluster information not centered, info services selection gray and not selectable, TEL mode, SMS, or notebook gray and not selectable.
-Modified alternator mounting bolts
-Oil consumption complaints
-Various CD malfunctions including 'No CD Changer" message, skipping, no recognition of magazine or discs.
-Weather-band reception, '00-'02 CLK Cabriolet
As requested:
Seems lots of people is having this problem as reported on the other thread.....
There are dozens of things that could cause a rough idle or hesitation. This is just one of the known problems with the ME control unit.
My Y2K CLK430 does experiences hesitation from time to time, do u recommend bring it back to the dealer and have the ME unit replaced ?? is this a valid fix ? what do i need to tell them in order to have this fix done ?
thanks, Howard
thanks, Howard
I have a question re: the CD player issues if you have a moment.
What is the fix for this as I have a 2002 CLK320 (cabrio) and I do experience that problem from time to time. Re-start the car and/or remove and replace the magazine and all seems OK, for a time.
Thanks again very much,
JR
just go to mbusa.com and click on specifications of the clk and it will have the ME stuff there....
Problem 1: CD changer goes to track 1 when starting car with command was rectified with updated command software.
Problem 10: Certain instrument cluster display not centered actually appear after the command software update.
I can't really tell you to bring your car to the dealer and tell them to replace your ME control unit, because that might not even be the problem. Just tell them what you told me, your car experiences hesitation from time to time. The part number for the updated control unit is 113 153 04 79, and it is a valid fix for many cars.
Took my car to the dealer and had them look at it today, they couldn't duplicate the problem (checked Air Flow Sensor & ME control unit), but I got a service B out of them and some mobil 1's put in 7000 miles ahead of my schedule maintenance .......
this may sound like a stupid question, what does ME stand for ??
which dealership do you work at ??
MBTech, thank you very much for your wonderful information.
JR
1. Whoever installed the changer didn't version code the D2B ring to include the changer.
2. The shock absorber springs on the changer are set to vertical when they should be set to horizontal, or vice versa.
3. The changer is defective.
4. The CDs are damaged, or recorded (burned)
Dave, really appreciate the list. However, E55MKB brings up an interesting point. Are there any non CLK specific problems that are very widespread? I know I'm not the only person to have a smart key replaced, is that becoming a common issue? Are there any other general MB issues to be aware of? Thanks.
