Schematic Question
Old Apr 18, 2002 | 03:11 PM
gareeb's Avatar
a car
Schematic Question
I have the schematics for all wiring in the CLK series.
I have found my VSS wires on the schematics. My problem is I'm not sure of the coloring due to the naming convention used by MB.
I have the wires colors for the left side are listed as "WS" and the other wire is "WS/GE"
The right side wires are listed as SW/GE and the other is listed as SW
I have a few guesses as to what they might be saying but I don't want to take a chance and blow up my command with the wrong wire. There is already a GR there is also a GN designation.
Anyone know
Here is my guess for the rear left side WS = White Stripe
Here is my guess for rear left side WS/GE White Stripe/Grey
I see a wire color listed as GN/VI = Green/Violet if so what the heck is GR? Grey? if so what the heck is GE?
Why do they make this so cryptic?
Anyone want to compare. Or better yet tell me what color the VSS wire is on the driverside that runs from the rear axle.
Old Apr 18, 2002 | 03:55 PM
Steph's Avatar
VSS wire
I looked on my VSS schematics and came to the conclusion that the driver side wire is is green/violet and the passenger side is green/black...As I was doing my retrofit, I decided to tap the wire on the passenger side but found that both the green/black and green/violet wires can both be found in a blue Molex in the kick panel in front of the sill plate. The green/black was connected to another wire; however, the green/violet was not. I decided to tap the green/violet and everything is working fine...not exactly what you asked....but hope it helps.
Old Apr 18, 2002 | 04:21 PM
gareeb's Avatar
a car
Is this the right front VSS front sensor?
Is this the front sensor?
Old Apr 18, 2002 | 04:39 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
They are abbreviations of the German words for the colours, unsuprisingly since the diagrams were probably drawn by a German speaker.
Some of the MB circuit diagrams have english abbreviatons, so here is a table
German English English
Abbrev Abbrev Word
BL BU Blue
BR BN Brown
GE YE Yellow
GN GN Green
GR GY Grey
NF TR Neutral/Translucent
RS PK Pink
RT RD Red
SW BK Black
VI VT Violet
WS WH White
My german is rubbish, so I havent put the german words in ...
Where you get WS/SW, it means main colour is white with a black stripe.
Occasionally you get WS/SW/GE . which means main colour white. black stripe (down length of wire), Yellow marks across wire at regular intervals
Old Apr 18, 2002 | 04:44 PM
gareeb's Avatar
a car
How come Steph has green/violet
Ami I looking at the wrong thing here.
Should I also have a green/violet wire that is not connected to anything also?
Old Apr 18, 2002 | 04:51 PM
Steph's Avatar
Yes, you should have...
....the same wire. The schematics that I used are applicable for all 208's 1997 and up.
Also...it is the front sensor.
Old Apr 18, 2002 | 04:55 PM
gareeb's Avatar
a car
I'm going to reroute some wires now
I see the green/violet designation on my schematics
I'm going to use that instead of the rear.
Old Apr 18, 2002 | 05:36 PM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Abbrev Abbrev Word
BL BU Blue
BR BN Brown
GE YE Yellow
GN GN Green
GR GY Grey
RS PK Pink
RT RD Red
SW BK Black
VI VT Violet
WS WH White
I added the GERMAN in CAPS; hope it helps:
BL BU Blue - BLAU
BR BN Brown - BRAUN
GE YE Yellow - GELB
GN GN Green - GRUEN
GR GY Grey - GRAU
NF TR Neutral/Translucent - NEUTRAL
(NOTE:I don't understand the F in NF)
RS PK Pink - ROSA
RT RD Red - ROT
SW BK Black - SCHWARZ
VI VT Violet - VIOLET
WS WH White - WEISS
Old Apr 18, 2002 | 06:18 PM
gareeb's Avatar
a car
Re: VSS wire
Mine is exactly the opposite.
Green Black is connected and Green violet is not?
Old Apr 18, 2002 | 07:02 PM
Steph's Avatar
Passenger Side....
....the green/black is connected....green/violet is not. Driver side might be just the opposite....either wire will work. Just tap the wire that is not connected.
Old Apr 18, 2002 | 07:23 PM
gareeb's Avatar
a car
Should I be getting 12volts on iginition?
I gettting a reading of 12 volts upon ignition on this wire can anyone confirm?
Old Apr 18, 2002 | 07:51 PM
Steph's Avatar
John sent this to me....
....and it was helpful in verification:
Now the VSS wire. I used a black/green wire. Look at the picture I enclosed, I found 2 black/green wires that were soldered and covered with grey nylon sleeve. I simply removed the grey nylon sleeve and inserted a black wire( that goes to the PIN 6 on C2 plug), put back the grey nylon sleeve and use heat shrink tube to tighten up. I am not quite sure if the CLK use the same color coded wire. Here is the way I verify the right wire. The VSS wire has a (-) negative polarity. To test this, use a voltage meter( from Radio Shack), put (+) positive to PIN 4 socketA and (-) negative to the suspected VSS wire. Do this when the car is parked and not started. You should get a + 12 V reading. Next part is a little tricky; have everything the same but start your car and you will notice the reading is dropped to nearly 0. This reading will change if you start to move your car forward( DON'T TAKE OFF!) but wouldn't go to 12V. The black/green wire is from the rear axle and the green/white is from the front axle.
Old Apr 18, 2002 | 09:58 PM
gareeb's Avatar
a car
Done
That did the trick
I'm cruising now
Old Mar 10, 2005 | 07:03 PM
MrLister's Avatar
sorry to bring up this thread again but i'm having problems with the vss wire.
i went to the passenger side kick panel and found a blue thing. it had a couple of wires in it
two being green/black and green/violet (neither wire is connected to anything) i tried tapping both but the thing is both always have a voltage of 12.5 and when i was going like 5kmph it would show me going 50+ on the avic-n1.
any suggestions?
Old Mar 11, 2005 | 07:59 PM
gareeb's Avatar
a car
any suggestions?
Unfortunately I don't have any suggestions to give you.
Good Luck
Old Mar 11, 2005 | 08:30 PM
mtimmy's Avatar
W208 55 & R170 230
where do you guys get all these wirings info.,
Old Mar 12, 2005 | 05:15 PM
captret's Avatar
2006 E320 CDI.SOLD..'02 CLK430 Cabrio(SOLD),08 Disco3..1996 FLH-TP, 2017 E300
Thumbs up
any suggestions?
MrL'
Read this thread:
https://mbworld.org/forums/clk-class-w208/100417-comand-nav-experts.html
Make sure you find the Blue 8 pin connector.
Good Luck
