looking for a cheap but usefull obdii reader
Old Aug 24, 2004 | 12:36 PM
TresX's Avatar
anyone have any recommendations....I searched and found ottoscan but it's a little pricey....all I want is to be able to pull the code and clear faults....no more ....thanks guys
Old Aug 24, 2004 | 02:46 PM
Brian_I.'s Avatar
w211 & w124
I have the Equus 3100. Works great but no scanner will clear the warning if the problem still exists. Even if you do clear the warning light, after you restart the car it will come back.
Old Aug 24, 2004 | 06:56 PM
proform's Avatar
Ferrrari 458 Lamborghini SL 570-4 Mercedes CLS63
Does it work well? How do you know what the codes mean? Seems like a deal for $120.00
Old Aug 26, 2004 | 03:50 PM
benzinoben's Avatar
99 CLK 320, 2000 GSXR 750
I got an Actron OBDII reader and it kicks serious ***! Just changed out my air mass sensor and cleared the error using the Actron tool. Whole project took me 20 minutes. I got my reader off of ebay for $90 brand new.
Old Aug 26, 2004 | 06:00 PM
SPIKES's Avatar
2019 S63 COUPE
could you please specify the model of actron. i tried one before but the connector would not work with my car.
thanks
Old Aug 26, 2004 | 07:30 PM
superstar's Avatar
03 R230 SL55 / 94 W124 E500
Is Actron OBDII compatible with Europe CLK?
Old Aug 27, 2004 | 04:53 PM
midget fidger's Avatar
E550 Coupe
what's the difference between this and the mb star diagnostic or whatever the thing they have at the dealer? my mechanic said that he bought the computer system the first year they had it for like $18,000...and then the next year there was an update so he had to pay another $1700 for it...but then the next year they upgraded again so he told them to shove it
Old Sep 2, 2004 | 04:21 PM
benzinoben's Avatar
The MB star diagnostic does a much deeper scan. You can do a ton more stuff to the computer in the car. The OBDII tool, gives you general diagnostic stuff and the ability for you to reset your Check Eng light and other faults.
Here is the Actron I got and has worked like a champ.
http://ebay.com and type in the following number in the search 2488276624 box.
Old Sep 2, 2004 | 05:07 PM
TresX's Avatar
Thats actually the same one I picked up on Ebay also.....I'll let you know in a couple of days how it works!
Old Sep 4, 2004 | 05:48 PM
barflux's Avatar
CLK 320 Avantgarde
Where do you stick the scanner? Does it come with the round socket in the engine compartment? Or do you have to buy it separately?
N
Old Sep 4, 2004 | 09:15 PM
Benz916's Avatar
1998 C230
what exactly will the scanner tell u? Just the fault code? or will it say your air flow meter is bad or something like that? My bro works at kragen auto parts...they have some their...have you guys seen any of those? I dont remember the name of them though.
Old Sep 9, 2004 | 03:40 PM
benzinoben's Avatar
Answers:
1. The socket or plug is located under the steering wheel just by the steering column. You will find a small black door about 2 inches wide with a lip on it. Open it and the waa-laa, there is where you plug the OBDII box into.
2. The scanner will pick all or any fault codes. The Actron box can actually run some minor tests on your sensors (like the Mass Air Flow sensor) and tell you it is working or not. More then likely you will get a check engine light before when one of your sensors craps out. You can also reset the error(s) and that will turn off your check engine light. If the problem is still there the light will come back on.
Oh ya, you can go to any of the OBDII sites like Actrons site and look up the code. The Actron actually gives you a crude description of the error but definitely look it up or simply call a parts store and tell them to look it up for you.
Old Sep 10, 2004 | 08:22 AM
barflux's Avatar
CLK 320 Avantgarde
I am looking to spend upto £500 or $800 on a Mercedes Diagnostics, that cover more than just the engine? Is there anything out there within this budget?
N
Old Sep 10, 2004 | 04:09 PM
superstar's Avatar
IS the OBDII compatibal with europ CLK ? or it is just for US models only?
