No crank no start
Old Jan 28, 2021 | 09:57 PM
1999clk320's Avatar
1999 clk 320 coupe w208
No crank no start
I have a 1999 clk 320 w208 . I have a No crank No start . It ran all summer long with no issues at all . Right before Thanksgiving it stop running. A week before Christmas it started up like nothing was wrong . That monday the week of Christmas it stopped again . I got a new g49 battery put in and still the same problem no crank no start . I was told from a local shop that I have power to the starter and alternator . But they never put my new starter in . What would make a no crank no start ? Please I need help . I really need my car . I travel to do car audio Installs and builds to make ends meet . I'm in Plainfield IL. Thank you for your time and Help .
Old Jan 29, 2021 | 09:35 AM
convicted's Avatar
1998 CLK 320
If you can get accessory power, you can put an OBD2 scanner on it and check for codes.
You can try disconnecting your battery for 15 minutes (to reset the ECM).
Check the batteries in your FOB.
That's where I would start.
G/L.
Old Jan 30, 2021 | 10:08 AM
cindyclk's Avatar
G/L.
agree...check battery in key
Old Feb 11, 2021 | 06:34 PM
CLK55_NYC's Avatar
2001 CLK55,2003 CL55AMG,2003 E55,2004 CLK55,2011 E350
check the crank sensor
Old Feb 12, 2021 | 01:15 PM
2dogsrock's Avatar
2000 Mercedes CLK 320 Convertable
No crank, no start
Originally Posted by 1999clk320
I have a 1999 clk 320 w208 . I have a No crank No start . It ran all summer long with no issues at all . Right before Thanksgiving it stop running. A week before Christmas it started up like nothing was wrong . That monday the week of Christmas it stopped again . I got a new g49 battery put in and still the same problem no crank no start . I was told from a local shop that I have power to the starter and alternator . But they never put my new starter in . What would make a no crank no start ? Please I need help . I really need my car . I tra to do car audio Installs and builds to make ends meet . I'm in Plainfield IL. Thank you for your time and Help .
I had the same issue, however it was intermittent. Then the turn signals and wipers were acting up. I know mine is an ignition problem. The EIS has a short. Mine will even cause the SRS light to flicker, and sometimes stay on. Problem here is that you just can't replace the EIS as it is married to the VIN. I found a guy on ebay that will repair the EIS and reprogram it. Good luck!!
Old Sep 30, 2022 | 03:26 AM
f Salinas's Avatar
mercedes clk 350 2006
Same issue
I have 2006 clk 350 I already changed both fuel pumps about 2 weeks ago but the car died on me while I was driving today and it’s the same thing it cranks but it doesn’t start could it b the fuel injectors ? Sometimes when I’m pressing on the breaks and I slightly let go of them it’ll shake pull itself also to mention I have no check engine light or any light whatsoever
Old Oct 1, 2022 | 09:04 AM
marko69's Avatar
'01 CLK 430 cab, '04 SL500 (230K miles)
Maybe I'm missing something here, but you have a NO CRANK, but you have power to the starter. If you have power to the starter then it should crank. I don't see any other problem then a bad starter.
Edit: I suppose you could have weak power to the starter, but you say you have a new battery. Could be the battery cable connections.
Old Oct 4, 2022 | 05:58 AM
2psycho's Avatar
CLK 230 Kompressor -02
It could be the solenoid on the starter. I had the same problem and fixed it that way. The tricky part is that you will not have any codes from a failing solenoid.
/ Psycho
Old Oct 5, 2022 | 04:25 PM
convicted's Avatar
1998 CLK 320
Right now mine has a brand new battery, a brand new starter, confirmed voltage to the starter, a new CPS and power to the fuel pump. Neither my son nor I can figure it out. It couldn't be injectors, because the car would still crank without fuel and the oil level is good and the oil looks good and the coolant looks good and it's had a recent tune up with plugs wires and coil packs, so I don't understand what we are missing.
