ABS/ESP Lights
Old Feb 13, 2021 | 04:36 PM
K McCarthy's Avatar
2002 CLK 430, 2005 CL600, 2009 Smart Fortwo
ABS/ESP Lights
Hi my 2002 W208 has suddenly developed an issue where BAS/ESP lights come on along with same message on center display. No other symptoms, the car runs and drives perfectly, brakes feel fine. After stopping and turning off the car the warning is gone until restarting and driving at freeway speed again. Brake lights are working, I did check that. Any ideas?
Old Feb 13, 2021 | 08:31 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Originally Posted by Plutoe
I dont know how you would test the wheel speed sensors with out DAS Xentry, but continue on with FUYAA may work
Just out of curiosity what is" FUYAA"?
2MERKS
Old Feb 14, 2021 | 04:17 AM
LateLife Crisis's Avatar
2001 CLK 430
Same Problem
I have the same situation, have cleaned front hub wheel sensors and toothed wheels, need to connect obd2 scanner when fault is active. Things I suspect are speed sensor in rear differential or the yaw/lateral accel sensor in boot. This has been happening for the last three months and have had new tyres fitted (manufacturer original size) to make sure this isn't the problem. Just need to remember to plug my scanner in before turning ignition off
Old Feb 14, 2021 | 05:51 PM
kartlude's Avatar
MB SLK 200
[QUOTE = LateLife Crisis; 8270494] Tengo la misma situación, he limpiado los sensores de la rueda del buje delantero y las ruedas dentadas, necesito conectar el escáner obd2 cuando la falla está activa. Las cosas que sospecho son el sensor de velocidad en el diferencial trasero o el sensor de aceleración lateral / guiñada en el maletero. Esto ha estado sucediendo durante los últimos tres meses y se han instalado neumáticos nuevos (tamaño original del fabricante) para asegurarnos de que este no sea el problema. Solo necesito recordar enchufar mi escáner antes de apagar el encendido [/ QUOTE]
You don't need to connect the obd2 before turning off the engine. The failure is registered and you can read it whenever you want.
Old Feb 15, 2021 | 01:05 PM
TEAsE550's Avatar
Veteran: Air Force
13 E550 Coupe & 99 C280
My old 2000 CLK 430 use to do the same thing. I found that when it happened if I shut the car off and re-started, then turned the steering wheel fully to the left 5-10 times and the righ 5- 10 timest while in drive with my foot on the brake and repeat while in reverse it would re-set whatever was sending the fault. Shut it off....re-start and all the warning lights would be gone. Mine tended to only do it after I would drive in reverse for for say more than 500' and the pavement was wet.
Old Feb 15, 2021 | 03:10 PM
K McCarthy's Avatar
I reset the fault with Xendry this weekend. I then drove it again and the issue returned, I will re-connect and retrieve the fault code to see what it is. Maybe I just need to do a few doughnuts!
Old Feb 15, 2021 | 07:21 PM
K McCarthy's Avatar
Xendry has 2 codes P2404 and C1200 both refer to brake light switch. Brake lights do work, maybe there is a relay which operates off of the switch that isn't working.
Old Feb 15, 2021 | 08:01 PM
cindyclk's Avatar
This is a common problem discussed for years on this thread...it's a faulty brake light switch...$20 at dealership...don't cheapo this and buy on ebay...should be fine after that
Old Feb 15, 2021 | 10:43 PM
K McCarthy's Avatar
Thanks Cindyclk, for that money I agree with you on OEM.
