Spark Plugs
Old Sep 7, 2004 | 11:55 AM
face118's Avatar
00' CLK 430
Spark Plugs
Hi,
Anyone try NGK Part # 4696 (Laser Irdrium IFR5D10) Spark Plug? or NGK (Laser Platium PFR5G-11)? My car reached 70k miles and have problem starting the car sometimes. I think to replace spark plugs can solve the problem..
Any Opinion?
Old Sep 7, 2004 | 02:23 PM
Mach430's Avatar
Try NGK BKR6EIX
Old Sep 7, 2004 | 06:00 PM
Bagher's Avatar
1999 CLK430
I see a lot of people on this board recommend NGK, are they better than Bosch platinum?
Old Oct 12, 2004 | 12:48 AM
oldnews's Avatar
That sounds like a lot of money for plugs. It's a relatively easy procedure to do it yourself. I use the NGK iridiumX. http://www.ngksparkplugs.com/apps/ca...engineid=27023
Changed mine out at 60,000. The original platinun Beru's are good plugs but the NGK's require less energy to spark and last as long or longer, though I wouldn't go over 30,000 miles on any plug.
From AllData:
Replace Spark Plugs
DANGER:
* Risk of death. Death may result if contact is made with parts carrying high voltages.
* Do not touch parts carrying high voltages.
* Persons who wear electronic implants (e.g. heart pacemakers) must not carry out work on the ignition system.
1.1 Remove top part of air cleaner housing
NOTE: Only on engines with air cleaner fitted at vehicle side.
2.1 Remove hot film mass air flow sensor together with air intake pipe, install
3 Remove engine trim panel or cleaner
NOTE: Remove engine cover or air cleaner by lifting vertically up and off the cylinder head covers.
4 Remove ignition coils (T1/4)
5 Disconnect spark plug connectors
NOTE: Pry spark plug connector off with "Double Opened Wrench" over cylinder head covers. See "Special Tools" given below.
6 Remove spark plugs (R4)
See "Special Tools - Spark Plug Wrench" given below.
Torque Spark plugs(All Engines) - 28 N.m (CLK 320-55)
Spark plugs(Engine 113.987/ 990/ 991) - 25 N.m
7 Install in the reverse order
I use a 17mm wrench, place behind the boot and push on the other end against the engine block. Use a 15mm wrench end to push the boots back on when the plugs arein, push until you hear a "click".
Do not pull on the plug wires.
Remove the bolt holding the coils and the wire going into the coils before removing the plugs.
LABLE WHICH PLUG WIRE GOES TO THE FRONT PLUG AND WHICH TO THE REAR PLUG FOR EACH COIL REMOVED. Easy enough.
I spent a total of 75$ and about 1 hour on the job for a 320, 12 plugs.
You have to remove the MAS on the passenger side, easy enough.
Good luck.
File Type: bmp
Old Oct 12, 2004 | 12:53 AM
oldnews's Avatar
The "lot of money" comment was to another post I saw where someone was quoted 250-450$ to change the plugs. Wrong thread.
Old Oct 12, 2004 | 09:35 AM
face118's Avatar
00' CLK 430
Ngk Spark Plug
I spent $180 for spark plugs and try to DIY to replace them.
Old Oct 12, 2004 | 03:10 PM
oldnews's Avatar
Which plugs did you buy?
I got my NGK's over the net at Clubplug http://www.clubplug.net/retail_iridium_ngk.html for 6.50 a piece no tax.
PepBoys also has them for about the same price and you don't have to wait 2 weeks for shipping.
The procedure to replace isn't to bad I thought.
Old Oct 12, 2004 | 03:59 PM
face118's Avatar
00' CLK 430
Ngk Spark Plug
I got the Laser Platinum #PFR5G11 which the retail price is $28.19 ea. I got it whole sale price $10.49 ea. + shipping
Old Oct 12, 2004 | 04:22 PM
oldnews's Avatar
You like those better than the iridiums, I guess?
Old Oct 12, 2004 | 05:07 PM
midget fidger's Avatar
E550 Coupe
what do you mean it has problems starting? does it just click once and shuts off? does it happen more when the car is cold than when it was just running? i ask because my starter is being replaced right now for this problem
Old Oct 13, 2004 | 09:15 AM
face118's Avatar
00' CLK 430
Yes, it just click once and shut off. I think because the spark plug is time to change...
So you think is the problem w/ the bad starter? how much to replace it?
Old Oct 13, 2004 | 04:49 PM
E550 Coupe
i dunno the symptoms of bad spark plugs, but with the starter i know it acts up more when the car is already warm. well i guess until it's really bad - two days ago it wouldnt start at all and had to be towed to the mechanic's. i think the starter is in the $150 range
Old Oct 13, 2004 | 04:59 PM
str8ridin's Avatar
05 E55
Alright, what are our OEM plugs? Specifically for the 430?
Old Oct 13, 2004 | 08:09 PM
oldnews's Avatar
The 320 and 430 have the same OEM plugs; platinum Beru's. French made.
Old Oct 14, 2004 | 12:45 AM
Brian_I.'s Avatar
w211 & w124
Today I was quoted $280 for parts and labor (independent shop). I was told the plugs being used were NGK but no other specs were given. Is this too much? He said the plugs are about $10.25/ea. and it would be 1.5 hrs. of labor @ $95/hr.
Old Oct 22, 2004 | 01:37 AM
Brian_I.'s Avatar
w211 & w124
Thinking about doing this job myself (with a friend of course) this w/e. Any advice from someone who's done it before?
Pretty please?
Old Oct 22, 2004 | 02:22 AM
Maestro's Avatar
W208 CLK320 & E39 M5
Did you buy 50 of them? They only cost a couple of bucks each.
Old Oct 22, 2004 | 03:23 AM
CERY's Avatar
subscribe
Old Oct 22, 2004 | 08:17 AM
face118's Avatar
00' CLK 430
Where you got for couple bucks ea.? If you get a that good of deal, share w/ everyone...
Old Oct 22, 2004 | 12:47 PM
str8ridin's Avatar
05 E55
That's a good deal, my man. Where did you get them at that price?
I need to order some. I heard clubplug is a good place...but haven't really checked.
Old Oct 22, 2004 | 07:00 PM
Maestro's Avatar
That still doesn't explain how that guy managed to pay $180 for them.
Old Oct 22, 2004 | 09:07 PM
face118's Avatar
00' CLK 430
Lets do some math.... $10.49 x 16 = $167.84 +tax
Beside, where you get that couple bucks good deal? I think everyone will like to know?
Old Oct 22, 2004 | 10:52 PM
Maestro's Avatar
I got my NGK's over the net at Clubplug http://www.clubplug.net/retail_iridium_ngk.html for 6.50 a piece no tax. PepBoys also has them for about the same price and you don't have to wait 2 weeks for shipping.
Old Dec 19, 2006 | 06:32 PM
krayzie_e99's Avatar
2000 CLK 320
FYI, you will need a torx t30 to remove the bolt on ignition coils
Old Dec 22, 2006 | 06:25 PM
charliev68's Avatar
2000 CLK430
it's your crankshaft position senser(cps), not your spark plugs.
bad sparkplugs would make your car misfire. it's always good to change the sparkplugs, also consider changing your wires while you are at it.
