List of Routine Maintenance After 50K miles
Old Sep 26, 2004 | 06:19 AM
funky102's Avatar
2000 CLK 320
Does anyone know where to get a list, or have a list, of the things to do or types of maintenance (eg. replace spark plugs at xx K miles) after a CLK hits over 50K miles? Thanks...
Old Sep 26, 2004 | 07:54 PM
clkal's Avatar
01' CLK55
i don't have a list, however, i can tell you what I had to replace after 50K:
1. front and rear O2 sensors.
2. mass air flow sensor.
3. a/c problem (temp. evap. sensor)
that's basically it....besides all the other small *****s.
Old Sep 28, 2004 | 11:25 PM
drli's Avatar
CLK430
(Sorry, ERRORS fixed)
At 50k they told me it was time to change the fuel Filter and charcoal gas tank filter. I was also told to change plugs at 4 years or 100K for 98 and 99, 5 years or 100K for 2000 up.
I had a front O2 sensor die before I made it to 50K.
Same with the mass air flow sensor, dead before 50K.
Also had to change the brake light switch...... right before hitting 50K.
Old Sep 29, 2004 | 02:33 AM
SpeedLimits?'s Avatar
E320 CDI
seeing as i am about to buy a 48K clk430 i am glad to find this thread.
Old Sep 29, 2004 | 10:29 AM
str8ridin's Avatar
05 E55
Originally Posted by drli
At 50k they told me it was time to change the fuel pump and charcoal gas tank filter. I was also told to change plugs at 40K for 98 and 99, 50K for 2000 up.
What?! Our spark plugs are supposed to be changed at 100K and I never have heard of changing out a fuel pump and charcoal gas tank filter at 50K. Was this the dealer that made you do this?
02 and MAFS yes, but the other stuff?
Old Sep 29, 2004 | 02:02 PM
drli's Avatar
CLK430
(Oh, sorry... I made many mistakes in my post above, and I was using ~10K per year)
the dealership told me:
SPARKPLUGS
4 years or 100K (which ever first) for 98 and 99
5 years or 100K (which ever first) for 2000 up
fuel filter and charcoal gas tank filter
50K
There are other things that are also time dependent, not milage based.
2 years brake fluid
3 years coolant
Old Sep 29, 2004 | 02:26 PM
str8ridin's Avatar
05 E55
Oh, I was gonna say!
Now, you've just reminded to change my fuel filter!
SPARKPLUGS
50K
2 years brake fluid
3 years coolant
Old Sep 29, 2004 | 06:13 PM
funky102's Avatar
2000 CLK 320
SPARKPLUGS
Good to hear. An independent service shop told me that the spark plugs needed to be changed between 60 and 80K at the cost of $400 minimum. They also said that if I wait later on, the spark plugs might be hard to remove (fused) and would need to charge more for the extra work. I just wanted to make sure they weren't trying to charge me extra and they seem they might be. Anyone else have similar experience with spark plugs?
Old Sep 30, 2004 | 02:00 PM
drli's Avatar
CLK430
This is what I was told for the CLK430... CLK320 may be different.
$400 for the CLK320 seems high. I had quotes for $400-$500 for the CLK430 which you may know has 16 sparkplugs. I do not know how many the 320 has.
