battery in my key died?
Old Nov 4, 2004 | 11:36 AM
CLKBSVegas's Avatar
a Black
Can the battery in the key die? I assume so. How do I change it?
Old Nov 4, 2004 | 11:41 AM
benzboi's Avatar
2000 CLK 320 (stock)
i would assume so..... all batteries die eventually..... i guess just open it up and put in the replacement?
Old Nov 4, 2004 | 11:43 AM
str8ridin's Avatar
05 E55
Yes it can. To replace, take out hte metal valet key. Once removed, look inside the slot for the valet key at the top...under the black relese button. You will see a white tab. Use the valet key to press that white tab in and the top wil pop up and slide out.
Old Nov 4, 2004 | 12:50 PM
JohnAMG's Avatar
3 Porsche rotation
You may not need to change the battery. One of my keys for E55 always seems to need battery every 4-6 months but I later discovered the springs that hold the 2 batteries together was loose and not applying enough pressure. So now a day I adjust the springs first before changing battery. This also happen to one of my CLK keys.
John
Old Nov 5, 2004 | 01:22 AM
CLKBSVegas's Avatar
a Black
It will not open!
Old Nov 5, 2004 | 08:16 AM
BklynBenz's Avatar
CL500
when mine died and when i went to the parts dept for a new one the parts guy swapped the 2 batteries out for me. he did it the same way str8ridin said to do it
Old Nov 5, 2004 | 09:52 AM
H-MAN's Avatar
'07 Carrera S, '31 A 5W hot rod, 4Runner. Sold CLK55
It will not open!
When you slide over the plastic block inside the key pry the top lip of the key off with your nail or a wedge.
Old Nov 5, 2004 | 11:28 AM
LamboMan's Avatar
CLK55, 911 Speedster, 930S, Lincoln Navigator, Lamborghini Diablo, Toyota Camry and 46 Chevy
Talking Mine died when I left the key in the wash.
I washed my key with my Jeans. The key survived but the battery died. I changed the battery and the key worked immediately.
Old Nov 5, 2004 | 06:01 PM
CLKBSVegas's Avatar
a Black
got it!
damn...I had to push hard! Thought I would brake it.
I bent the contacts a'little and know it is ok. What do you do if it dies? That little key don't open the doors!
Old Nov 6, 2004 | 01:54 PM
midget fidger's Avatar
E550 Coupe
The little key doesn't open the doors?? That's not supposed to happen...
Old Nov 6, 2004 | 01:59 PM
LamboMan's Avatar
Cool Little key does open the door?
I thought the little key opens the door but does not start the car. Please correct me if I am wrong.
Old Nov 7, 2004 | 11:48 AM
CLKBSVegas's Avatar
a Black
try it. Mine does not
Old Nov 7, 2004 | 01:17 PM
E550 Coupe
Either your locks are messed up or you have the key for another Mercedes in there. My key works in the trunk, the door, and the glove compartment. If you bought the car used, go back to the owner's house and try em in his/her other cars :-D
It's not like you'll be able to take off with their car anyhow so ask em to check their other keys and see if they have yours swapped in one of theirs.
Old Nov 8, 2004 | 08:17 AM
benzboi's Avatar
that sounds quite odd to me....like lamboman said, it should open doors/ glove vcompartment, just not start the car
